Electric Water pump and controller
Old Jul 6, 2016 | 07:42 AM
Caddyshack's Avatar
Caddyshack
10 Year Member
Default Electric Water pump and controller
Hi all,
I was looking at these electric water pumps and controllers and wondered what everyones thoughts are.
I like the idea that you can set it to run after you turn the car off to prevent hot spots in the engine.
You set the target temp that you want the car to run at and it varies the speed of the pump to hit the target and warm / cool the engine. It also kicks the fan in too. They have alarms etc that you can program.
The other benefit is that I could delete the water pump pulley etc to give more room in the engine bay. At the moment I only have an ally 205 Rad to cool the YB and as my car is quite high power it might need extra cooling at some point. At the moment I am not struggling with temp so space would be more important to me. I have cured the pressure problem with the new header and relief cap along with a swirl pot.
http://www.demon-tweeks.co.uk/motors...roller-combo-2
Old Jul 10, 2016 | 05:51 PM
costina's Avatar
costina
Live long and prosper!!
Toby i have used them on a few cars at work they do work well but imo suited to race cars than road cars.
Paul
Old Jul 12, 2016 | 08:17 PM
stevieturbo's Avatar
stevieturbo
C**t
I used one once....never again.
Mechanical pumps work, they're often free already fitted to an engine. They're reliable. They do pretty much everything you need a water pump to do, and they do it well.
What's that about not fixing things etc ?
Old Jul 12, 2016 | 08:29 PM
costina's Avatar
costina
I would rather not use one tbh and on our next car i have dug my heels in and said no.
What probs did you encounter Steve?
Old Jul 12, 2016 | 09:14 PM
stevieturbo
C**t
Quite simply it just didnt work. And then with removal of the mechanical impeller and drive pulley, it created more problems with the belt drive.
Old Jul 12, 2016 | 09:17 PM
costina's Avatar
costina
I found they bubble up the water too.
Unless its a drag engine its not worth the effort.
Old Jul 13, 2016 | 06:26 AM
Mark Shead's Avatar
Mark Shead
Toby don't do it as nothing wrong with the stock pump.
Mark
Old Jul 13, 2016 | 10:25 AM
jontysafe's Avatar
jontysafe
BMW use electric water pumps on their 35i engines.
I am looking at using one possibly in conjunction with the mechanical pump.
All the usual suspects though do not flow enough at a decent head. For instance you show a Davies Craig 1bar and it doesn't flow anything.
The BMW pump is a Pierburg cwa 400 and needs a CAN controller otherwise it runs at 95% permanently. It needs 30amps to run! The controller you can use is here
Old Jul 13, 2016 | 10:27 AM
jontysafe's Avatar
jontysafe
http://www.tecomotive.com/en/tinycwa-en
I am only looking at this because I have a rear mounted rad that is quite raised.
In your set up I really don't think it's necessary.
I will be installing from radiator bottom hose to engine.
Old Jul 13, 2016 | 10:50 AM
jontysafe's Avatar
jontysafe
The cwa 400 will flow 150ltrs per MINUTE, most others are rated at litres per hour. It will flow this at upto 0.8bar.
I found a lot of info here
http://mbworld.org/forums/w211-amg/411058-intercooler-pump-you-didn-t-know-about-4.html
The cwa50 and 100 are the intercooler pumps.
Old Jul 13, 2016 | 02:45 PM
Caddyshack's Avatar
Caddyshack
10 Year Member
Thanks all, will give that a swerve then, it was just to save space as my pulleys are about 10mm from my fan housing
Old Jul 13, 2016 | 02:56 PM
stevieturbo
C**t
Stewart Components make far better pumps than anything DC have.
I've even seen Prodrive use them on some LeMans engines.
But for 99.9% of users when the mechanical pump works....it's just daft to change.
Marc sierra
49
Dec 24, 2021 12:12 PM
cossie330
Mar 8, 2016 07:51 AM
Thrush
Oct 14, 2003 11:51 PM
starturbo
Oct 9, 2003 09:39 PM
rizla
Sep 30, 2003 04:42 PM
