Boost control, Cosworth
Old Jun 21, 2016 | 10:53 PM
chrisa3's Avatar
chrisa3
Default Boost control, Cosworth
Quicky.
Stage 3 Saff 4x4 on standard T3. dark greens 3 bar map etc etc.
Only peaking at 1.25 bar and holding 1 bar. Plumbed turbo direct to actuator with 1/2 hole of preload and its lifting at 0.55 bar approx (8psi). so actuator looks ok i think and Amal valve is performing some kin of boost control, but cant get it boosting any higher that above. Is that not low for this setup? i would have thought it should be peaking around 24psi and holding 20-22psi. (obviously tuner dependant, but still seem very low).
Any ideas? could it be a dodgy amal valve. >?
Note: The original qouted boost results were with a full 1 hole and a bit extra of actuator preload, so previous owner has obviously been trying to raise boost unsuccessfully.
Old Jun 22, 2016 | 09:28 AM
cossie2's Avatar
cossie2
..have you checked that you dont have any leaks around..
Old Jun 22, 2016 | 09:51 AM
Loomer's Avatar
Loomer
re jet the amal valve
Old Jun 23, 2016 | 12:58 PM
chrisa3's Avatar
chrisa3
Default Amal Valve Jets
Yeah thats the next step. tried all other ideas. TRying to remember which port needs modding. anyogot got a desciption of how jet sizes in each port effect the boost characteristics.?
thanks
Old Jun 23, 2016 | 03:32 PM
Loomer's Avatar
Loomer
At that spec a simple increase in the jet size in port R will allow the amal to bleed more air and increase boost.
Just make sure you monitor AFR and for det while doing so.
4x4kiwi
12
Jul 20, 2024 02:55 PM
costina
42
Jan 8, 2017 03:17 PM
22
Apr 20, 2016 04:02 PM
cossie330
Apr 10, 2016 07:54 PM
Ellsa
Apr 1, 2016 03:22 PM
