ford sierra trailing arms
Old May 19, 2016 | 10:00 PM
andylamb's Avatar
andylamb
Default ford sierra trailing arms
looking for some help to identify the proper ford sierra trailing arms
the one i have taken of has a bracket for the shocky
the bit where the wheel bearing bolts onto isn't as thick on broken one as on the complete one also note no shocky bracket
Attachment 7646
whole one
ford sierra trailing arms-shocky-2.jpg fatter bit where wheel bearing bolts on
ford sierra trailing arms-shocky-1.jpgbroken one
main photo in reply below
Old May 19, 2016 | 10:02 PM
andylamb's Avatar
andylamb
whole one & my broken one
Old May 20, 2016 | 09:10 AM
The Youth.'s Avatar
The Youth.
i'm going to guess at a sierra estate i'm sure they run a different shock absorber set up than every other sierra
steve
Old May 20, 2016 | 12:16 PM
The shockers on estates sit in the trailing arm in between the spring if i remember correctly.
Old May 20, 2016 | 12:18 PM
Them arms do look like normal sierra ones and not hatchback.
Ive never seen a ar snap like that.
Old May 20, 2016 | 08:11 PM
Stroker's Avatar
Stroker
10 Year Member
Yes the shock runs up the middle of the spring on a estate. They also have a large hole in the middle of the spring recess where the shock can be fitted or removed.
Old May 21, 2016 | 10:30 AM
robrs2's Avatar
robrs2
Sierra estate rear arms. not the one you have
Looks like someone may have cut off the shocker bracket on the one you have. Guess it was on a kit car?
There are a few rear arms for the sierra if yours is a disc braked type. one for none cosworth i.e xr4x4, gls4x4, ghia4x4,dohc 4x4.
You can tell by the shocker mount is this shape
The cosworth ones are like this
Just be aware that there are different toe and camber setting between the arms. If you dont have a match pair you will find the car driving very odd.
Old May 21, 2016 | 10:44 PM
andylamb's Avatar
andylamb
ford sierra trailing arms-sierra-1.jpgthe ones i bought on ebay have had the shock mount cut off [ATTACH]
Jackingleby
47
Sep 16, 2016 09:26 AM
JohnRamo98
Wheels and Tyres
May 3, 2016 06:08 PM
155lee
Apr 28, 2016 11:18 AM
creator
Apr 26, 2016 10:10 AM
Robbbo
Apr 21, 2016 07:20 PM
