Coilover Spring Length.
Old May 1, 2016 | 07:42 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Default Coilover Spring Length.
I know little about suspension. I wish to replace my Front coilover springs & had no idea of there original length. They measure 8 1/4". I assume they wont have stretched so what im asking is it possible to have shortened by 3/4" over a 10 year period. 8" or 9" im not sure.
Cheers Rod
Old May 1, 2016 | 08:07 PM
Caddyshack's Avatar
Caddyshack
10 Year Member
I would think a company like spax, koni or other would want to sponsor your car?
Old May 1, 2016 | 08:20 PM
jonfoc's Avatar
jonfoc
I've never see a set compress by 3/4" but I suppose it could happen. Softer springs tend to compress a little more.
I work at leda so I've seen a few.
Old May 1, 2016 | 09:45 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
This is a Leda set-up.
Old May 2, 2016 | 05:37 AM
jonfoc's Avatar
jonfoc
I'll see if I can find them on our system Rod. If they have been standing for some time it's possible they could start to sag. I'm off in today for a bit of "Home work" so I'll have a chat with the boss and scan our records.
It might be prudent to get them to us for a dyno session just to make sure they're still performing at original spec or close to it at least..
Old May 2, 2016 | 08:47 AM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Thanks. The spring is marked S9 on it then 200. Im confused as I thought it was a 8" 275lb rate spring. We are talking maybe 15 years ago when these were purchased.
Old May 2, 2016 | 10:02 AM
jonfoc's Avatar
jonfoc
Just from those marks it's a 200lb 9" spring Rod.
Old May 2, 2016 | 11:25 AM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Thanks for that. I cant remember when that Spring was fitted maybe I complained it was too hard with the 275lb rate Mark usually fits. I didn't not track the car & it was to my likeing as a road car. Thanks again.
Old May 2, 2016 | 11:47 AM
jonfoc's Avatar
jonfoc
No problem Rod. Like I said though I'd be getting the dampers dyno'd to be on the safe side. If the springs have sagged by .75" I'd be having new ones too. Let me know if you need me to sort you some.
Old May 2, 2016 | 12:58 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Yes I need new Springs that's for sure. 9" long & 2.5" I/d. The spring rate will be discussed with Mark it appears I changed the 275 ones to 200 at some stage. A price would be nice. Maybe Leda would want to sponsor the Fastest Cosworth there has ever been ( I can only ask) all records set on its suspension. Thanks again for your input.
Old May 2, 2016 | 01:59 PM
jonfoc's Avatar
jonfoc
No worries Rod. I'll ask the question for you, watch this space.
Bosch
Jun 3, 2016 12:27 PM
jonmac1
May 9, 2016 09:24 PM
Birty7810
May 1, 2016 07:55 PM
haz87
Apr 27, 2016 05:05 AM
anthony lea
Apr 17, 2016 08:23 AM
