YB head thickness question for someone that knows there stuff!
Old Apr 24, 2016 | 12:56 PM
carterhall14@hotmail.com's Avatar
Default YB head thickness question for someone that knows there stuff!
got a head here 2wd cosworth YB which measures 137.5mm would you say this has had its day? or would it be ok to use with maybe a WRC gasket if so what mm gasket?
Old Apr 24, 2016 | 01:03 PM
Bart's Avatar
Bart
I going to use one which is 137,2mm. Use pistons with valve pockets and measure everything to calculate c/r. Wrc cars and rallycross cars run heads like this to raise c/r and run between 350 and almost 600bhp for rallycross so that will do for me.
Old Apr 24, 2016 | 01:10 PM
thanks for the reply buddy yeah i was just a little concerned that my valves would clash with my pistons. so you rekon get my pistons pocketed?
Old Apr 24, 2016 | 05:25 PM
costina's Avatar
costina
Live long and prosper!!
Yep pocket pistons but make sure you cc it. Then have you map adjusted to suit.
Also its advisable with any skimmed head to have adjustable pulleys to get timing back to spec.
Regards
Paul
Old Apr 24, 2016 | 06:05 PM
great advice here thanks for that mate
Old Apr 25, 2016 | 07:09 PM
Bart's Avatar
Bart
Regards
Paul
Yes thats how you need to do it.
Dont be afraid to raise c/r to 8.5 or even 9/1, mapping is the most important bit to keep it in one piece.
Old May 12, 2016 | 02:24 PM
Stu @ M Developments's Avatar
PassionFords Creator
The head thickness limit of 138.68mm quoted by Cosworth has nothing to do with compression ratio guys, its the limit cosworth quote as the absolute max material removal allowed before you compromise the valve seat integrity.
Old May 16, 2016 | 07:08 PM
so stu do you rekon i will be ok using the head at 137.5mm providing i use pocketed pistons and a group A head gasket? thanks.
Old May 16, 2016 | 07:12 PM
Caddyshack's Avatar
Caddyshack
If the max is 138.6 and you are under then surely it will be at the risk of valve seat integrity, I guess that then comes down to spec of engine, boost, usage, revs etc. I bet the factory have a large tolerance of safety.
Old May 16, 2016 | 08:44 PM
steveboyslim's Avatar
steveboyslim
The Mountune works WRC engines had thinner than 138.68mm heads fitted when built from new.
Steve
Old May 17, 2016 | 06:09 AM
cool i will go ahead with the build and hope for the best thanks lads
Old May 29, 2016 | 06:20 PM
right this is my last chance as i will be assembling the engine tomorrow so just to build my confidence. I should get no valve to piston contact providing my pistons are pocketed and i use a victor reinz group A gasket. nervous thats all im asking again for lol. Thanks.
Old May 29, 2016 | 07:35 PM
Adam-M's Avatar
Adam-M
When its all built up mate I'd avoid bouncing off the rev limiter as when the heads are that low there's not a lot that holds the valve seat in place which is why you see so many drop valves into cylinders.
Old May 30, 2016 | 07:46 AM
thanks for the reply mate. Yeah i will be lets say taking it easy as that will be in my head at all times. i basically want reliability more than anything now so i can just enjoy the thing for once lol.
cossynut2
39
May 17, 2016 07:27 PM
-=Cossie=-
12
May 2, 2016 09:35 AM
shanek2041
Apr 28, 2016 07:59 PM
155lee
Apr 28, 2016 11:18 AM
Jules44
Apr 24, 2016 10:09 PM
