HOT N BOTHERED :-(
Old May 16, 2004 | 01:34 PM
cossie carl's Avatar
cossie carl
Default HOT N BOTHERED :-(
my saffy cossie 4x4 header tank keeps pressurising.... senario is, after a half hour or so, when i stop, i can hear cooling system bubbling, so i have to loosen header cap to release pressure and after it stops, i leave it for a few mins while air bubbles out, then top up. temp gauge reads normal, not overheating, so ??????
not looking forward to replies
CARL.......
Old May 16, 2004 | 02:06 PM
Dave Henshall's Avatar
Dave Henshall
headgasket....? you can have a compresion test done - and get a exhaust gas analyser (MOT style) and place that in the top of header tank when u open it - will show if combustion gasses are being forced intot thecooling system from the cylinders.
Old May 16, 2004 | 02:08 PM
DazC's Avatar
DazC
Don't go off the standard Ford guage. For some reason the Cossie guages are shat and don't work properly.
Old May 16, 2004 | 02:55 PM
cossie carl
i always thought that if h/gasket was gone,then i would
have oil in the water, or water in the oil. is this correct.
i,ve only had the car for 6 weeks and i seem to be chucking
ŁŁŁ,s at the funking thing all the time .
suppose if head has to come off, a bit of porting could be an option
Old May 16, 2004 | 05:21 PM
Fast Guy's Avatar
Fast Guy
I'd go with the head gasket on this one.
My montego used to blow water out after thrashing it, but that's cos they put the radiator off a 1.6 on it and it couldn't cool it enough.
BTW I've got oil in the water on my current car, but sod it, it's still running ok, so if it blows it blows
Old May 16, 2004 | 09:57 PM
EscRSCos's Avatar
EscRSCos
defo headgasket mate get a grp A then itll be mint!!!
Old May 17, 2004 | 12:33 AM
Dilly's Avatar
Dilly
get a compression test before you pull the head off. does the header tank smell of fumes?
Old May 17, 2004 | 01:43 AM
Toe Knee's Avatar
Toe Knee
its made by Ford, nuff said
Old May 17, 2004 | 02:52 AM
cossie carl
no smell of fumes that i can detect.... also runs as normal, but
afraid 2 use it now.... . is the cap supposed 2 be vented ??
if this was blocked, could that be my problem ??
Old May 17, 2004 | 06:36 AM
pugo's Avatar
pugo
Default could be the cap
don't go pulling the thing to bits before you have a compression test done as i have had this before and it was the cap!!
pugo!
Old May 20, 2004 | 08:09 PM
cossie carl
gonna change the thermostat tomorrow, and flush rad and change cap.
wish me luck
.....CARL......
Old May 20, 2004 | 08:58 PM
Antilagnos8inj2wd's Avatar
Antilagnos8inj2wd
Dont worry bout it my car always bubbles has done on all three engines ive had just leave it and keep an eye on your water level and temp gauge.
no prob
Old May 20, 2004 | 09:34 PM
cossie carl
when this bubbles on yours, much pressure ???
mine has serious pressure, have to loosen cap and
release pressure over a few mins......when i eventually
{safely} take off cap,it still releases bubbles as if there
has been an airlock, few more mins. when releasing pressure
it also spews out water ??? <--- like that
Old May 21, 2004 | 06:31 AM
cossie carl
bttt..... also, where is the temp sensor that controls
when the fans come on ??? and where on engine is it ??
Old May 21, 2004 | 07:52 AM
JesseT's Avatar
JesseT
I had the same bubbling scenario whenever I topped up the header tank too full. It was cured by rewiring the fan so that it will spin after the engine has stopped. The hot turbo right behind the radiator is a bad combination in a RST after shutting the engine. There was nothing wrong with the headgasket. It's just that when the engine stops, the water flow stops, but several parts still remain very hot for a while and can cook the water.
Old May 21, 2004 | 10:43 AM
Dave Henshall
it may or may not have oil/water mixed - depending where it has actually blown - mine didnt have mayo in it either
Old May 21, 2004 | 02:39 PM
cossie carl
done the thermostat.. vented the cap..
took it 4 a spin..
STILL THE FOOKING SAME...
Old May 21, 2004 | 02:58 PM
wes's Avatar
wes
Did you bleed the cooling system when filling it up? And are you using antifreeze or just water?
Old May 21, 2004 | 04:06 PM
cossie carl
used coolant/antifreeze....
booked it into sick bay next fri for tests
if h/gasket is gone, am replacing with Grp 1
any improvement over standard ????
i can feel the chuck money at it bug coming on
CARL
Old May 21, 2004 | 05:29 PM
B11GNS's Avatar
B11GNS
Welcome to the world of cosworth ownership
Old May 21, 2004 | 06:21 PM
cossie carl
um....
i think i mean Grp A head gasket
porting anybody ??
Old May 22, 2004 | 09:50 AM
Dave Henshall
id go for the cometic gasket - more expensive - but u can eliminate the head blowing ever again
Old May 22, 2004 | 10:07 AM
cossie carl
HOW MUCH ARE THESE COMETIC GASKETS ??
WORTH THE EXTRA OUTLAY ??
BENEFITS ????
Old May 22, 2004 | 10:49 AM
Dave Henshall
about 130-150 depending where u get it from - woodford garage have them in stock.
they are as the gasket should be, not a bit of cornflake box with a bit of tin foil folded round the cylinder holes. they are like the evo gasgets are as std - ive not heard of one go yet. if the engine is in good nick and uve had the head off and had it all done - u might as well spend the extra bit now than have to risk having to have the head off again a few months later when the frosty packet blows again.
Old May 22, 2004 | 08:31 PM
Wangdian's Avatar
Wangdian
jumping on your thread, so i apologize.
Exactly how do you go about bleeding the cooling system. Do you just run the engine with the header tank cap off untill the engines warm?
Old May 24, 2004 | 07:55 AM
Dave Henshall
with the header tank cap off and, there is a small bleed screw (8mm spanner needed) in the top of the thermostat housing -it has a copper washer under it. remove this and wait until water with no air is flowing. screw back in, and let the car warm up, keeping the water level to full in the tank as it gets pumped round.
Fiddy
21
Sep 29, 2015 06:10 PM
PeterLucas
Sep 21, 2015 11:36 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
