Anti Roll Bar Bush Size Issues
Hi there,
I have a Focus 2005 Mk2 Estate 1.8TDCI, I need to change the anti roll bar bushes but I am getting a bit confused after I measured the standard bars. I stuck a digital vernier caliper on the bars at the weekend and got 22.5mm for the front and 22mm for the rear
I want to chuck some poly bushes in there but struggling to find the right size. Seems like quite a large diameter anti roll bar? The closest to this size I can find is 21mm for an 2.5 ST which I clearly do not have
Do the bars reduce in size around the bush?
Help!!
Help!!
Daveysaff
Nov 15, 2015 05:03 PM
