Tricky one here! bosch 044 on cosworth priming issues?
Old Sep 18, 2015 | 05:22 PM
wheelwizardrefurbs's Avatar
wheelwizardrefurbs
Default Tricky one here! bosch 044 on cosworth priming issues?
ok i have a bosch 044 fitted to my cosworth and its got a really bad splutter as if on 3 cylinders but once its right up in the rev range it seems fine. ive noticed that when the ignition is switched on the pump only primes for a second not the normal 2-3 seconds is this normal? ive replaced the cps cts phase sensor (gapped correctly) new spark plugs genuine 071`s its running stage 3 msd chip 803`s T34-55 3 bar map sensor etc this car has had my life and all im doing is chucking money at it with no success! can somebody please tell me where im going wrong? thanks in advance!!
Old Sep 18, 2015 | 05:39 PM
Caddyshack's Avatar
Caddyshack
10 Year Member
That doesn't sound like fuel pump at all, as long as the back of the pump is flooded then it will be fine, also the fuel rail is all at the same pressure so it would not miss one cylinder.
My personal and expensive opinion is new engine loom, standalone ecu and coils on plugs.
Old Sep 18, 2015 | 06:23 PM
wheelwizardrefurbs
cheers for the reply mate yeah im trying to avoid the dreaded new loom but if it needs it then so be it. its as if its being choked on low down power very spluttery.
Old Sep 18, 2015 | 06:48 PM
wheelwizardrefurbs
also on the fuel rail feed there is some sort of saucer shaped valve? can i remove this? what is it?
Old Sep 18, 2015 | 07:17 PM
Caddyshack's Avatar
Caddyshack
10 Year Member
Can you take a pic of it? I expect it needs to be there.
Might be worth checking the correct spark plugs and gap specs along with cleaning all earths.
When I got mine I junked the lot and went with new loom.
Old Sep 18, 2015 | 07:22 PM
costina's Avatar
costina
Live long and prosper!!
Just take it to a specialist you have posted more problems yet again..
Save the hassle and time get it sorted before you have to build a new engine.
Old Sep 18, 2015 | 07:32 PM
Caddyshack's Avatar
Caddyshack
10 Year Member
That is a good point, give it to one expert to fix, do it once and do it properly.
Old Sep 18, 2015 | 08:39 PM
Tim Wharton's Avatar
Tim Wharton
Hi
Always start with a few basic checks
Even so called profestionals some times slip up here.
Do a conpression test to make sure your engine is good mechanicaly before you get too technicial
If thats all good a fuel pressure test would be good---ok
Check all your multiplug conections
Make sure there are no air leaks and all the pipes are on the plenim
Check the Map sensor pipe and that there is no petrol contamination
Cheers Tim
Old Sep 18, 2015 | 08:59 PM
wheelwizardrefurbs
Hi tim and thanks mate i will go over everything you have mentioned in the morning however i have good compression across all cylinders the map sensor is brand new but i must say it is an unbranded one. i will clean all connections too. Thanks.
SmudgerByName
52
Jul 28, 2016 06:14 PM
manuel boeckx
13
Oct 3, 2015 02:29 PM
ekjim
Aug 27, 2015 05:20 PM
Aug 14, 2015 07:29 AM
