COSWORTH WATER PUMP
Old Apr 3, 2005 | 02:40 PM
barney's Avatar
barney
Default COSWORTH WATER PUMP
AS ABOVE I HAVE JUST FITTED A 200 BLOCK INTO MY 2WD COSSIE WHICH WATER PUMP WILL I HAVE TOO USE
AND IS THERE ANY MORE THINGS I WILL HAVE TOO CHANGE
CHEERS BARNEY
Old Apr 3, 2005 | 10:52 PM
richm's Avatar
richm
AFAIK you can run either 2wd or 4wd pump, but use the appropriate thermostat housing for the pump you choose, although this will probably be dictated by which head you have, as the thermo housing fixings are different.
I suspect it'll be easier to use a 2wd pump if you have a 2wd head and thermostat housing (and a LOT cheaper )
Oct 9, 2015 07:38 PM
cameron2
Aug 25, 2015 07:18 AM
David Potasnick
Ford Fiesta
Aug 22, 2015 10:54 PM
MARKYMARKONE
Aug 20, 2015 12:55 PM
Aug 14, 2015 07:29 AM
