Engine spray ?!?!?!?
Old May 11, 2004 | 06:06 PM
Daz-Tyler's Avatar
Daz-Tyler
Default Engine spray ?!?!?!?
i was woundering if it is possible 2 spray your engine(e.g:sump,engine block)
also if you can how do i go about doing it and any advice that yous could give me please
thanks
daz
Old May 11, 2004 | 06:37 PM
Toe Knee's Avatar
Toe Knee
On or off the car?!?! u can get high temp paints and ur better off brushing that spraying. Ive used hammeite before which works ok too!!
Old May 11, 2004 | 09:15 PM
Daz-Tyler's Avatar
Daz-Tyler
thats the thing i was thinking about!..the heat when the car is running!
so it is better brushing it on then??????
how much is that kind of paint and hwta is it called plz m8
cheerz
Old May 13, 2004 | 02:40 PM
Switch's Avatar
Switch
I used engine blick paint, bushed it on. wasnt alot either. around Ł10 from amotor factors.
Old May 13, 2004 | 06:49 PM
Daz-Tyler's Avatar
Daz-Tyler
cheerz m8
what colours can u get?
what gives the best results spray or brush on?
cheerz again!
p.s:how much r the engine holders(in your pic?)
Old May 16, 2004 | 08:51 PM
nicksaph's Avatar
nicksaph
carplan do engine paint you can get most popular colours red, black, blue, silver, etc for about fiver a tin from most accessory shops and the engine stands are around the Ł50 mark but are well worth it. hope this helps
cheers nick
Old May 16, 2004 | 09:09 PM
Daz-Tyler's Avatar
Daz-Tyler
big_Rad
Sep 15, 2017 09:36 AM
fuzzy
21
Feb 15, 2016 10:26 PM
manuel boeckx
13
Oct 3, 2015 02:29 PM
track.focus'd
Aug 12, 2015 05:53 PM
paceo
12
Aug 4, 2015 08:50 PM
