S2 KE jetronic help!!!!
Old Oct 2, 2014 | 07:29 PM
rsmog33's Avatar
rsmog33
10 Year Member
Default S2 KE jetronic help!!!!
Doing my head in now This is the last chance for my mfi before I rip it out.
Long story but I will keep it short. My S2 will not run for love nor money. Every part of the fuel system has been checked and renewed. You name it, it has been checked and renewed.
Cold start it fires up but wont idle. Then it will eventually start holding down metering flap but still wont idle and dies. Then wont restart at all.
Checked everywhere for air leaks. Had metering unit reconditioned and set up on a test rig.
Got it going once in the last 2 months, took it for a spin was running great till pulled up at lights it idled then died and wouldn't restart. Looked a right t**t.
Ive spent thousands on this car restoring it gradually. Bodywork and engine wise. Set up last year on rolling road and pumping out 215 bhp which was great. Now I want to push it in the river.
Any sympathy would be most appreciated but advice would be great.
Thanks guys
Old Oct 2, 2014 | 08:17 PM
mk2grp1's Avatar
mk2grp1
going sideways in a fwd
tried a known working throttle position switch? correctly set
checked your injectors spray pattern ?
new dizzy cap & rotor arm ? new plugs gapped to 1mm
fuel pump buzz bad ?? worn out ???
Old Oct 2, 2014 | 08:26 PM
rsmog33's Avatar
rsmog33
10 Year Member
Hi. Ive had the following : Brand new TPS and set up. Brand new injectors and great spray pattern. Brand new plugs with perfect gap. Reconned dizzy and new cap/ rotor arm. New uprated 941 bosch fuel pump.
So annoying!!!!!!
Old Oct 2, 2014 | 09:15 PM
john_3.0s's Avatar
john_3.0s
Fuel pressure ok? Could be a duff pump
Old Oct 2, 2014 | 09:23 PM
rsmog33's Avatar
rsmog33
10 Year Member
Fuel pressure was tested and ok. New uprated pump from Burton Power. These cars are so annoying. The closed loop system means just one thing a nats fart out and it will play up!!
Old Oct 2, 2014 | 10:23 PM
Billy_RS's Avatar
Billy_RS
You got a dump valve? They are known for leaking. Checked all boost pipes for leaks etc?
Old Oct 3, 2014 | 06:15 PM
rsmog33's Avatar
rsmog33
10 Year Member
Hi Billy. Yeh tried removing dump valve and fitting my original hose but still the same. All boost hoses are new.
Drives you nuts doesn't it
Old Oct 3, 2014 | 06:20 PM
Billy_RS's Avatar
Billy_RS
I love RS Turbos, but when they start misbehaving like this I hate them lol!
Although it's an expense and a pain, your best bet is to convert it to EFI from a Fiesta RS Turbo, which will eliminate the Metering unit problems for ever and you get turbo chatter as an added bonus
Old Oct 3, 2014 | 06:24 PM
rsmog33's Avatar
rsmog33
10 Year Member
You are dead right. When it is running well its so good. Ive given mfi plenty of chances so efi could well be on the cards but finding all the parts for that now is quite hard. Oh happy days
Old Oct 15, 2014 | 08:24 PM
rsmog33's Avatar
rsmog33
10 Year Member
Problem solved....fuel pump relay kept melting ( on my second third one now ). Fuel pump was drawing too much current on burning out the relays.
Sourced a new one through Motorsport Developments...a Bosch 941 upgrade...and with a bit of new wiring and connectors its on and running like a dream
Back on the road and running great...happy days
Old Oct 15, 2014 | 09:04 PM
Billy_RS's Avatar
Billy_RS
Great news
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
Shaunc
Escort Range
Jul 29, 2015 09:50 PM
Shaunc
Jul 19, 2015 05:16 AM
avatardrex
Mar 16, 2011 06:42 PM
Garage19
28
Nov 4, 2005 08:06 AM
