cams
Old Nov 4, 2003 | 07:28 PM
alan rainbow's Avatar
alan rainbow
Default cams
whould you use this cam the back bearing is marked
Old Nov 4, 2003 | 07:53 PM
Doug's Avatar
Doug
Personaly I wouldn't m8 plus has it picked up in the Head ?
Old Nov 4, 2003 | 08:10 PM
alan rainbow
not seen the head they come out of i brought them as being vgc off someone on here
Old Nov 5, 2003 | 04:54 PM
alan rainbow
help
Old Nov 5, 2003 | 05:01 PM
Stu @ M Developments's Avatar
PassionFords Creator
Personally, No mate.
If it nips up, the cam will probably snap clean in half.
Old Nov 5, 2003 | 05:31 PM
alan rainbow
stu can i have the cam machined so i can use it i brought these cams off someone on here i not say his name yet but i was told they were in vgc but as you can see there not
Old Nov 5, 2003 | 05:48 PM
You cant really machine the cam as the cam caps will no longer be any use mate as they are oversize to the cam journals.
Old Nov 5, 2003 | 06:45 PM
alan rainbow
looks like its a new one then
Old Nov 6, 2003 | 03:06 PM
Switch's Avatar
Switch
so who did you buy it off then?
Old Nov 6, 2003 | 04:32 PM
alan rainbow
i dont want to say at the moment i have had a word with them and they are going to try and get me another or sort something out so it aint that bad
Old Nov 7, 2003 | 10:47 AM
Switch's Avatar
Switch
ok thats cool, if they arent screwing you
Old Nov 17, 2003 | 02:58 PM
cossy abuser's Avatar
cossy abuser
I have thrown better in the bin, as Stu says if it picks up you will have a big repair bill
Old Nov 17, 2003 | 11:24 PM
Rs Gus's Avatar
Rs Gus
impreza wrx sti version 8
fook that bin fodder imo
Old Nov 18, 2003 | 11:12 AM
SapphyMike's Avatar
SapphyMike
do cams have a marking on the back bearing on the exhaust side?
Old Nov 18, 2003 | 02:18 PM
cossy abuser
what kind of marking
all reprofile tagging should be etched on the end of the cam opposite from the cam wheel
Old Nov 18, 2003 | 02:29 PM
SapphyMike's Avatar
SapphyMike
it looks like a score in the bearing. on every bd8 inlet cam i've seen has this marking (similar to that above)
Old Nov 18, 2003 | 02:38 PM
cossy abuser
bearing surfaces should be SMOOTH
Although some inlet have a groove machined dead in the centre to help oil flow and for identification I believe
Wait to get corrected now
Old Nov 18, 2003 | 02:48 PM
SapphyMike's Avatar
SapphyMike
thats what i was referring to!!
Old Nov 18, 2003 | 02:57 PM
cossy abuser
Oh well there you go
should be there if its dead central on the journal, but should be deeper than the one pictured above
Old Nov 18, 2003 | 03:33 PM
SapphyMike's Avatar
SapphyMike
thats the boyo
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
