Mondeo TDCI engine swap - TDDI?
Old Aug 27, 2014 | 06:40 PM
Rufusw5's Avatar
Rufusw5
Default Mondeo TDCI engine swap - TDDI?
Hi All,
I've been offered a 2003 TDCI mondeo for scrap value with injector issue's, I was just wondering if anyone has any experience swapping a TDDI engine in? I know they're pretty solid, and seem to be cheap and plentiful.
I'm guessing I'd need the complete engine (obviously +injectors manifolds fuel pump starter etc), engine wiring harness and the ecu..
On paper it's an easy enough engine swap, has anyone tried it, are there any unforseen issue's?
I spent some time googling it expecting loads of people would have tried it given the troublesome early TDCI's and comparatively solid TDDI's, but either i'm looking in the wrong place or it seems not....
And.. I guess i'd need the ECU to be from the same engine. Do mondeo's still have transponder keys?
Old Aug 31, 2014 | 10:00 AM
karl mcghee's Avatar
karl mcghee
Originally Posted by Rufusw5
Hi All,
i have some wiring diagrams
doesnt work they are completely different wiring all together i go on a transit forum an some one done this and could never get it going
if you were to take this on it would have to be the full wiring system from the donner including clocks/ecu keys transponder ring etc
yes
even the injectors will cost you 400 quid
Old Aug 31, 2014 | 10:17 AM
chris cdti's Avatar
chris cdti
Don't forget you need the electric fuel pump for the tddi
Old Sep 17, 2014 | 09:31 PM
forevaford's Avatar
forevaford
just about to do this conversion myself mate to my 2003 tdci estate. it lookts a bit tricky though as the engine harness is integrated with the main car harness so dash out and all the rest of it. im having a go though as im sick of spending 600 on injectors every 2 years!
JoeyBoyden
Jan 4, 2024 02:36 PM
Alun Gregory
Sep 6, 2015 09:40 AM
