Fuel pump
Old Jul 5, 2014 | 03:41 PM
r5matt's Avatar
r5matt
Default Fuel pump
running ofab, 1.9zvh, t34, Intergrale injectors , grs
I was plodding along at 50 and suddendly out of the blue the car kind of spluttered and then cleared then spluttered again and then popped and banged (imagine running out of fuel that's the only way to describe it) it did this for around 2/3 mins and was fine again for around 20 miles and then repeated it. I pulled over and allowed the car to idle then set of again. It drove fine for 17 miles and then repeated itself , I left it a week and thought with it being a much cooler day it I'd give it another bash but it's kinda got worse, I mean now I can't get past 3k with out it all but dying on me. When I release the throttle and reapply it I get acceleration again but when I reach 3k it died again, the pump is making an odd noise so I'm "assuming" this is the cause? Am i on the right track?
It's a bosh 023 fuel pump should I swap like for like? I see MD do an uprated cossie fuel pump that's the equivalent of this would that be ok to use?.
Cheers Matt
Old Jul 6, 2014 | 07:19 PM
opposite lock's Avatar
opposite lock
It could be a dirty pump , have you changed the filter ?
Its a Fiesta turbo pump right?
Old Jul 6, 2014 | 10:19 PM
r5matt's Avatar
r5matt
The filter is 4 years old but has covered less than 200 miles. As for the fuel pump, I'm not 100% of its origin when I google Bosch 023 it's just sort of says in a sense that it's an up rated item but the car in question is a FRST.
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
155lee
Oct 24, 2015 11:11 AM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
tib2220
Sep 14, 2015 12:33 PM
