Siemens Deka
Old Jun 1, 2014 | 04:15 PM
philt's Avatar
philt
Default Siemens Deka
Hello,
Does anyone have any experience with the above injectors? I am thinking of trying a set of 60lb (ebay 221167061182) - the seller confirms that they are a direct replacement for the originals. Just wondering how good the idle will be being quite a large injector - I am aiming for around 330bhp at the mo but want to build in some headroom for the future .Any comments welcome.
Cheers,
Phil.
Old Jun 2, 2014 | 07:41 AM
Red_bull's Avatar
Red_bull
Direct replacement and they are much bigger? ECU will need adjustment for this i guess. Or are you on diy management
Old Jun 2, 2014 | 08:25 AM
philt's Avatar
philt
Sorry, meant to say they are a direct physical replacement, same dia O rings and same length. They obviously flow a lot more than standard injectors. I will be using an Omex 710 hence the need for high impedance injectors, not much available from Bosch - the Siemens Deka items listed are a good price but probably over capacity for what I need. This will not be a problem as long as idle/low speed performance is ok, and plenty of scope to increase power in the future if req.
Nov 1, 2015 06:53 PM
Danielbetty
Oct 3, 2015 06:01 PM
timsrs
22
Sep 24, 2015 08:14 PM
cos elle
Sep 16, 2015 06:37 PM
sygjim
21
Jun 28, 2006 01:30 PM
