advise required boost adjustment
Old Mar 27, 2005 | 07:48 PM
rossco22's Avatar
rossco22
Default advise required boost adjustment
I am shortly to become the proud owner of a g plate 2wd saff cos! With the following engine spec
t3/4 turbo,dark green injectors,3bar map sensor, 4x4 intercooler, bajoo chip, low comp pistons etc
The thing is its been a few years sinse ive had a quick rwd car, an to start with i would like to turn the boost back down whilst im getting use to it!
its running around 25psi at the minuite an id like it down to around 15 to start with! Basicly what is the easyest way to do it? Will i need to by a new set of standard injectors an a 2bar map sensor and a stage 1 chip? or can i just turn it down with some sort of boost controller or bleed valve? or will there be to much fuel at lower boost because of the bigger injectors?
Any advise would be much greatly recived!
Old Mar 27, 2005 | 08:01 PM
Niall.b's Avatar
Niall.b
just lengthen the wastegate actuator rod, if u have a boost gauge fitted, check the readings as u go
Old Mar 27, 2005 | 08:10 PM
rossco22's Avatar
rossco22
Ok so i wouldnt need to change the injectors an that back over no?
Old Mar 27, 2005 | 08:11 PM
rossco22's Avatar
rossco22
Forgot to say yes i does have a boost gauge
Old Mar 27, 2005 | 08:12 PM
Dilly's Avatar
Dilly
leave it the way it is mate......control the boost with your right foot
Old Mar 29, 2005 | 05:59 AM
Niall.b's Avatar
Niall.b
Guy over here races an ex touring car rs 500. He runs eight greys and adjusts the boost in car from bout 250 up to full whack at 540 and it runs well. as dilly says, leave it, as i think you will get used to it very quickly and will soon be looking for more never mind less
IainRS1700T
Sep 25, 2015 06:44 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
oilman
Sep 23, 2015 11:21 AM
Marino
Sep 12, 2015 11:10 AM
markk
Sep 9, 2015 08:11 AM
