2wd ignition timing
Old Mar 27, 2005 | 07:38 PM
stesrst's Avatar
stesrst
Default 2wd ignition timing
jus a quick one does anyone no if you can adjust the ignition timing on a cossie by moving the dizzy? mine seems to be running at 14 degrees on tickover ive been told they should run at 16 degrees, non of the pins have been linked in the timing adjust plug neither (near the ecu), i have just fitted a new phase sensor if that helps but im certain i set it up right. has anyone delt with this before?
Old Mar 27, 2005 | 07:51 PM
CosRush's Avatar
CosRush
Afraid not, the ECU controls the timing.
Although there is a connector near the ECU that alters the timing to allow for different Petrol grades. Cant remember off the top of my head what timing figures it adjusts it to, but worth a check....
If i get a chance i'll have a look tomorrow....
Old Mar 28, 2005 | 05:30 PM
foreigneRS's Avatar
foreigneRS
Testing the future
it's quite common for the woodruff key or keyway on the crank pulley to be worn which can give you a 2 degree difference easily.
Old Mar 28, 2005 | 06:34 PM
stesrst's Avatar
stesrst
cheers dudes, is 2 degrees out much of a problem?
Old Mar 28, 2005 | 06:53 PM
pugo's Avatar
pugo
yes.....is the simple answer.........get it sorted
pugo
Old Mar 28, 2005 | 08:27 PM
stesrst's Avatar
stesrst
ok mate ill pull my crank pully off 2moro an have a look hopefully wont be to expensive to fix - but then again its a cosworth
Old Mar 29, 2005 | 06:30 AM
foreigneRS's Avatar
foreigneRS
Testing the future
2 degrees is not a big problem, unless it was mapped too close to the limit in the first place. always use super unleaded and it will be safe. you could always connect up some of the jumpers to retard it for lower grade fuels.
van_dogg_pavvy
Mar 3, 2016 09:30 AM
Zoggon
Aug 10, 2015 10:39 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
Old ford
Jul 31, 2015 06:50 AM
