2wd engine using late spec pulleys
Old Apr 24, 2014 | 05:33 AM
JaseP's Avatar
JaseP
in a puddle
Default 2wd engine using late spec pulleys
hi, hopefully someone knows this off the top of their heads, can the 2wd cosworth engine use the late 4x4 pulleys? I have heard the crank shaft ends are different, but also i wonder about the 2wd lower radiator hose routing. My reason for asking is, 12 years ago i added aircon and made some custom brackets to do this, ie ps and alt on left and ac on the right, but, i'd like to run the proper brackets for the factory look
Old Apr 28, 2014 | 07:42 PM
opposite lock's Avatar
opposite lock
Im sure this has been done but know nothing about it.
And theres definately someone here that can advise.
There are some good traders here who may also have the parts you may need.
Old May 14, 2014 | 09:45 PM
adriankt77's Avatar
adriankt77
Yeah the later pulleys can be fitted as I've just done it to mine. I wanted the multi grove belt rather then the old V belt. I had to make a lower pick up bracket and water pump pulley needed modifying. I used the 4x4 alternator on a drop bracket and left the power steering pulley at the min till I can make / modify one to run of one multi grove belt . Hope this helps
SmudgerByName
52
Jul 28, 2016 06:14 PM
JoeyBoyden
14
Aug 15, 2015 09:51 PM
RsS2daz
Aug 14, 2015 05:26 AM
ray barker
Aug 7, 2015 09:00 AM
Old ford
Jul 31, 2015 06:50 AM
