Megasqirt/efi tps wires.
Old 13-04-2014, 05:10 PM
ozzy69
ozzy69's Avatar
Default Megasqirt/efi tps wires.
Can some one tell me which wires go where i have a blacktop turbo using efi inlet and ms i just need to no what wires go to the throttle position sensor i have edited the diagram to show you.Also for the idol control valve where does the other wire go on the ms?is it just an earth?
Old 14-04-2014, 08:44 PM
Churtz
Churtz's Avatar
Green /brown to blue on wiring diagram
Brown to grey on wiring diagram
Other wire earthed.
Idle control valve.... Switched earth to ecu (live comes from fusebox)
Old 15-04-2014, 11:25 AM
ozzy69
ozzy69's Avatar
Other wire earthed.
churtz you are a star thanks,i had the car professionally wired when it has bike bodies but had to cut the tps wire and i never had the icv hooked up thankx again.
DixieTheKid
11
06-06-2020 11:20 AM
muffster
13
03-09-2015 09:40 PM
cozzy jeff
31-08-2015 04:14 PM
Roosie
15-08-2015 08:09 PM
adriansaleem
01-08-2015 09:28 PM
Quick Reply: Megasqirt/efi tps wires.
