Indicators malfunctioning. Mk1 Sierra
Old Mar 24, 2014 | 10:55 AM
tjRS500's Avatar
tjRS500
Default Indicators malfunctioning. Mk1 Sierra
What would cause the indicators to click faster on one side than the other ?
I have changed/cleaned fuses and checked earths etc......can't see any broken wires in indicator/headlight looms aswell
Also the left side repeater will not work at all aswell as the front right indicator ... Would it be the switch on the stalk itself that is causing it go be erratic?
All bulbs are perfect
Any suggestions ?
Old Mar 24, 2014 | 11:09 AM
dojj's Avatar
dojj
Resident Wrestling Legend
remove all the bulbs
clean up the contacts
replace bulbs
if it's the switch then nothing works other than the hazard lights
Old Mar 24, 2014 | 11:24 AM
tjRS500's Avatar
tjRS500
replace bulbs
What would cause one side to flash faster than the other ?
Out of curiosity if fuse was dirty would some lights works or would none work?
Old Mar 24, 2014 | 12:37 PM
cossie891's Avatar
cossie891
Its a bulb out that makes it flash faster
Old Mar 24, 2014 | 12:41 PM
tjRS500's Avatar
tjRS500
Okay I've tried new bulbs so it must be a dirty contact , il get a look and get back if no luck
Cars for Mot on the 4th first time in 15 years so few small problems to sort out
Cheers for advice
Old Mar 24, 2014 | 12:47 PM
cossie891's Avatar
cossie891
Right check the earths mate and wiggle the wires
Old Mar 24, 2014 | 01:19 PM
boy-racer-1's Avatar
boy-racer-1
Wrong bulbs fitted as Barry said
Old Mar 24, 2014 | 01:25 PM
cossie891's Avatar
cossie891
Its nothing serious mate annoying but not serious just go back through the lights on that side and you will find it
Old Mar 24, 2014 | 01:35 PM
Cossy Mike's Avatar
Cossy Mike
Double check the bulbs again mate, I know they may work BUT
I had an XR2 and one side would flash faster (as if a bulb had gone) and it had the wrong bulb in the front.
It was a 24v commercial bulb, I swapped it for a 12v and everything worked again
Old Mar 24, 2014 | 06:37 PM
Cossiemainful's Avatar
Cossiemainful
Did you check the relay? If the fuse were the prob, not one indicator would work, if I'm not wrong ....
Oh, have to correct my thoughts: seems not the relay, cause both sides would click faster then, but who knows
Old Mar 28, 2014 | 12:46 AM
tjRS500's Avatar
tjRS500
Got the front indicator sorted today... Seal had perished in the bulb holder and water got in and had corroded the earth. Quick wire brush and change of bulb and it's working again. Didn't have time to check the side repeater so hopefully the same problem !
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
155lee
Oct 27, 2015 04:55 AM
Dr. Ickxs
Sep 15, 2015 10:15 PM
Cossikev
Sep 13, 2015 02:00 PM
The Enigma
Sep 12, 2015 10:12 PM
