mk1/2 focus engine change
Old Mar 11, 2014 | 09:02 PM
ryannbingham's Avatar
ryannbingham
Default mk1/2 focus engine change
Hi I have a 1.4 zetec se engine in my focus but I've killed it lol... I want to replace it with a 1.6, what I want to know is will a silver top zetec s 1.6 just drop straight in?
Old Mar 11, 2014 | 10:02 PM
leeby's Avatar
leeby
if you fit a 1.6 zetec se you would just need the engine with ecu and keyfob(chip) as the engine loom and ancillaries are the same, if you use the silvertop you need engine with full engine loom which runs from under bonnet through bulkhead to ecu and gem module then down drivers side to fuelpump also ecu and key bit more of a ballache
leeby's Avatar
leeby
sorry forgot to mention to fit the silvertop its as more involved as fitting a 1.8/ 2.0 as need the same parts pretty much
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
track.focus'd
Aug 12, 2015 05:53 PM
