Starting a garaged s1
Old Mar 25, 2005 | 04:12 PM
jezzyp's Avatar
jezzyp
Default Starting a garaged s1
Hello all,
Ive got a s1 thats been in my garage for coming up 3 years now, and i wanted to know what should I check before I try starting it?
It's not been started in all that time so obviously I'll need to charge the battery, but what else should i do/check before its started?
Any pointers would be appreciated.
Ta
Old Mar 25, 2005 | 04:22 PM
Dilly's Avatar
Dilly
probably a good idea to change your oil as well and build up the pressure before you start it
Old Mar 26, 2005 | 09:24 AM
NUTS RuS's Avatar
NUTS RuS
Yep just whip off the coil lead plug and spin it over until the oil light goes out.
Chuck in some fresh petrol, put the coil lead back on and give it a try.
Check for any water leaks from perished rubber once upto pressure too
CossieRich
30
Sep 8, 2015 10:08 PM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
Anutternutter
Aug 21, 2015 06:07 PM
Bloody-Fox
Aug 3, 2015 07:48 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
