s2 running problem!!
Old Mar 25, 2005 | 11:02 AM
escortrsmatt's Avatar
escortrsmatt
Default s2 running problem!!
when my car is hot only intermittently it will start idling very lumpy then gets worse very quickly.and just cuts out.then if i try to drive it judders and backfires!it will start again straight away but will cut out unless i hold the revs up.when i do this the fuel pump speeds up and slows down and the revs go up and down.if i leave the car for a while then it as if the problem never happened!any help appreciated guys, cheers.
Old Mar 26, 2005 | 03:00 PM
K18NEO's Avatar
K18NEO
distributor on the way out? dodgy fuel relay? Spark plugs? Too much air on tickover? could be many things.. start from beggining.. does it sound like its a firing problem, or spark problem, or fueling?
Old Mar 27, 2005 | 11:25 AM
escortrsmatt
i was thinking it might be something on the fuel side of things beacause of the pump speeding up and slowing down?maybe the ecu??
Old Mar 29, 2005 | 08:51 PM
zvhrst's Avatar
zvhrst
i would try taking fuel relay out and wiring it direct on a switch, i had similar problem on my car when 1st bought it, did this been fine ever since,
and hasn't burnt pump out yet witch i got told it would do, and had car 3 years
Old Mar 30, 2005 | 05:51 PM
davecosworth's Avatar
davecosworth
IM BACK
sounds like the pressure regulator or the accumulater
wheelwizardrefurbs
Sep 23, 2015 09:14 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
