Courier starting mystery...
Old Feb 2, 2014 | 09:04 PM
axxeman's Avatar
axxeman
Default Courier starting mystery...
Hello guys, boy do I need some help here please...
2001 Courier van 1.8 Tdi.
Tuesday night did 20 mile trip with no problems. Weds night and it will not start at all. Glow plug light starts flashing if you crank for any length of time. Did start it 3/4 times out of 30 odd attempts BUT it won't catch.
Fuel filter new two weeks ago
Cracked injectors and fuel getting to them
Cracked banjo inlet to pump and fuel there too
Error code p1664 shows which kind of suggests low fuel pressure and possible air leak in the fuel delivery system?
Any help appreciated as I am tearing my hair out.
Thank you.
Old Feb 2, 2014 | 09:21 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
Pumps are shocking on Fiesta/couriers
used to be the first thing i would sell when one came in for breaking
Old Feb 2, 2014 | 09:32 PM
axxeman's Avatar
axxeman
Yes indeed, the Bosch VP44 has a pretty foul reputation. However, I fail to see how it could go just as I am turning the key AND the engine surely wouldn't try to start at all if it was done in?
Old Feb 2, 2014 | 09:40 PM
botters's Avatar
botters
competant bodger
i tend to find when these pumps are on the way out they usually die shortly after having the filter changed as random as it sounds!
Old Feb 2, 2014 | 09:42 PM
axxeman's Avatar
axxeman
That would be extremely weird...
Old Feb 2, 2014 | 09:43 PM
axxeman's Avatar
axxeman
Let's assume, for the sake of debate, that it is air on the inlet side causing the problem. How and where does one start looking for an air leak in fuel supply lines?
Old Feb 2, 2014 | 09:52 PM
botters's Avatar
botters
competant bodger
not really its usually because instead of using suction or a primer pump to bleed the air out of the fuel people just crank them until they fire which runs the pump dry and is usually enough to finish them off
Old Feb 2, 2014 | 09:57 PM
axxeman's Avatar
axxeman
Understood, but I didn't do that. I filled the new filter to the brim and kept the lines full too. It started on the key immediately and behaved impeccably for a fortnight. Then it decided to play dead...
Old Feb 2, 2014 | 10:35 PM
Cossie Sean
P1664 is injection pump control module issue (box on top of the VP44)
you really need to measure fuel pressure and check the CAN network to/from the PCM
Old Feb 3, 2014 | 07:56 AM
axxeman's Avatar
axxeman
Could you expand on that second line please Sean?
Thanks.
Old Feb 4, 2014 | 10:57 AM
axxeman's Avatar
axxeman
Well, the local guys spent an hour rigging up a diesel supply line to the pump, bypassing the van lines, and it still wouldn't start. The total fault code readout is as below;
p 0409
p 0404
p 0149
p 1664
Are there any sensors on the Endura 1.8 Tdd1 that could cause non start? If so, where are they located.
Thanks.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
xrmalin
Sep 13, 2015 06:52 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
stevierob
Sep 7, 2015 07:09 PM
kevin36
Sep 2, 2015 06:24 PM
