Bonus Zetec conversion crank sensor question
Old Jan 20, 2014 | 11:20 AM
Doodah's Avatar
Doodah
Default Bonus Zetec conversion crank sensor question
Hi still ant got it in yet, nearly ready though I think
Can anyone tell me which crank sensor should I use? There's one on the scrapyard-Zetec I'm fitting which I assume (hope) works...then there's the one from the 1.4 cvh I got the efi flywheel from, or the one on the car at present (1.1 xflow). The only one I know is working is the one on the car at the moment so I'd use that but will it fit on the Zetec and work ok with the cvh flywheel?
Thanks
Old Jan 20, 2014 | 03:38 PM
studabear's Avatar
studabear
mine uses the zetec sensor with the cvh efi flywheel
Old Jan 22, 2014 | 10:19 AM
Doodah's Avatar
Doodah
Ta guess I'll go with the Zetec sensor then, unless my 1.1 one is a straight swap, just don't want to have to have the gearbox & flywheel off and buy another set of flywheel bolts if it's faulty
...or (not wanting to tempt fate) do these sensors ever actually go wrong & need replacing?
Old Jan 22, 2014 | 11:08 AM
haz87's Avatar
haz87
Yes they do, but not often (unless debris gets in the box/someone damages it when removing/putting on the gbox).
Old Jan 26, 2014 | 11:09 AM
Doodah's Avatar
Doodah
Many thanks chaps
Old Jan 26, 2014 | 06:21 PM
big.p's Avatar
big.p
Mine uses a efi cvh one mate
manuel boeckx
13
Oct 3, 2015 02:29 PM
wheelwizardrefurbs
Sep 23, 2015 09:14 PM
Anutternutter
24
Aug 31, 2015 01:24 PM
Roosie
Aug 15, 2015 08:09 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
