Rebuilding a Borg Warner T5
Old Jan 11, 2014 | 08:34 PM
rcr's Avatar
rcr
Default Rebuilding a Borg Warner T5
Hi,i am rebuilding a Borg Warner T5 gearbox. The main shaft on my gearbox is a bit worn where the input bearing sits.Common fault! It is the bearing inside the input shaft. I need to know if the main shaft is 21mm in diameter(mine was) or it is maybe 22mm?
Old Jan 11, 2014 | 08:45 PM
DixieTheKid's Avatar
DixieTheKid
Pick-up P100 Power!
Ive got a manual somewhere, dont know if it will have the sizes but ill dig it out. good luck getting 5th gear off! They are bastards!!
Old Jan 11, 2014 | 09:08 PM
rcr's Avatar
rcr
Smile
The 5th gear went of without problems.No need of puller etc
Old Jan 14, 2014 | 12:23 PM
opposite lock's Avatar
opposite lock
Had a quick search for this with no joy. You could try a specialist such as CTS or Phil Peacock Transmissions.
bobsworth
77
Mar 24, 2016 09:30 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Mc5506
Oct 5, 2015 09:57 PM
jonnyenglish
Sep 21, 2015 07:31 AM
