Ford focus
Old Dec 19, 2013 | 03:07 PM
Arsenalmad_d's Avatar
Arsenalmad_d
Default Ford focus
I have a 2003 ford focus 1.6 zetec and the fan is coming on from cold and not allowing the choke to go off...... Is this the fan switch?
Old Dec 19, 2013 | 04:06 PM
chris cdti's Avatar
chris cdti
May be an issue with one of the coolant temp sensors
Old Dec 19, 2013 | 08:22 PM
Red_bull's Avatar
Red_bull
Think so too. Build in safety to let it run all time then
Old Dec 19, 2013 | 08:32 PM
GVK.'s Avatar
GVK.
If it's got AC and you're using the 'screen defrost' setting on the fan speed, the AC will cut in, putting the fan on.
No seperate fan switch, the fan is ECU controlled.
Only temp sensor is the 'CHT' sensor that's fitted in between two of the spark plugs.
It doesn't go into coolant, it has a sacrificial end that when fitted and torqued correctly makes contact with the metal head casting.
Old Dec 20, 2013 | 12:18 AM
Arsenalmad_d
Cheers lads and someone told me earlier it might have summing to do with the screen heaters soi. Went out started it up with out the heaters and the problems gone...... Fucking fords lol cheers tho (y)
Old Dec 20, 2013 | 12:31 AM
Arsenalmad_d
And also GVK when I got this problem I noticed when I was going slow or around corners I would get a missfire, would this be he same problem with the heater as I haven't been out in the car since I sorted it
jaysoc1
Aug 21, 2015 05:38 PM
taylora1409
Aug 12, 2015 12:06 PM
