cosworth ecu plugs same as anything else?
Old Dec 11, 2013 | 08:00 PM
d.kenny's Avatar
d.kenny
Default cosworth ecu plugs same as anything else?
basically i have got a megasquirt ecu i bought a while ago and never used as i never had anything to connect it up to
i have now also got a 2wd sierra cos and as its a bit of a project and the ecu is of an unknown quantity/old i want to have a go at using the megasquirt on the car but also want to be able to plug the original back in when i actually need to move it etc
so...
what i want to do is get an ecu to canibalise and desolder the connector off so i can make a plug and play loom for the megasquirt and also be able to revert back to original with no problems
therefore my question is...as a cosworth ecu second hand seems to fetch good money working or fried is there any other ecu of any other model i can use that has the same 35 way plug or whatever it is as on my l6 ecu?
cheers
Old Dec 11, 2013 | 08:04 PM
Gadget's Avatar
Gadget
Spanner monkey
The cossie abs ecu is the same plug, and worth not a lot!!
Old Dec 11, 2013 | 08:09 PM
d.kenny's Avatar
d.kenny
thats sound then
i might just butcher the abs ecu as i dont think it works anyway and lets face it...who needs it?
i take it you know this from plugging the wrong plug into the wrong ecu previously?
haha
Old Dec 11, 2013 | 08:14 PM
d.kenny's Avatar
d.kenny
anyone done the megasquirt thing before to?
i think in actual fact i could just piggy back the megasquirt to the original if i really wanted so i could go distributorless aswell which would justify the cost of a megasquirt anyway!
Old Dec 12, 2013 | 07:22 AM
oldford's Avatar
oldford
35-pin connector is the same on a lot of Weber-Marelli ecu's from back then. These ecu's were used on Fiat's and Lancia's.
Some old Bosch motronics also use this 35-pin connector.
Old Dec 12, 2013 | 07:46 AM
rsnissan's Avatar
rsnissan
Ferrari F40
Old Dec 12, 2013 | 05:50 PM
d.kenny's Avatar
d.kenny
gonna buy an abs ecu tonight and give it a try
is anyone up on the megasquirts and or has a base map for one on the cosworth?
think mine is an ms1 v3
was originally used on a 1.8t i think and had coil on plug but i wanna use it with the dizzy for now and as i never built the ecu im unsure exactly of how it works and what may need changing around inside
Old Dec 14, 2013 | 09:57 AM
martysmartie's Avatar
martysmartie
Originally Posted by rsnissan
Ferrari F40
Correct, these along with others such as the Meserati Bi-Turbo had two of them, (one for each bank)
Martin
Old Dec 15, 2013 | 05:07 PM
Blades Rally Team's Avatar
Blades Rally Team
Been Trying to get my Megasqurt MS3 + MS3X running for about 2 years seems that there is not a lot of help on the MS Forum and everybody wants CASH to help even though I paid Ł650.00 for the unit I have attached a photo of my breakout boxName:  IMG_20131215_175320_zpsf94b1fed.jpg
Old Dec 15, 2013 | 06:20 PM
costina's Avatar
costina
Live long and prosper!!
Yes they are the same just green
Paul
Old Jan 9, 2014 | 01:00 PM
d.kenny's Avatar
d.kenny
have you had no joy getting yours running?
i just want to see if the ecu will light up and if i can get any readings on my laptop at all
it will keep me quiet for a few hours haha
need a pin out diagram now!
Old Jan 10, 2014 | 06:33 PM
Blades Rally Team
Hi I am still not getting mine to run I have a pin out diagram that I have used (how can i insert it) so that anyone can let me know if you or anyone else can see any issues
big_Rad
Sep 15, 2017 09:36 AM
wheelwizardrefurbs
Sep 23, 2015 09:14 PM
jay030787
Sep 18, 2015 07:34 PM
Aug 14, 2015 07:29 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
