What grease?
Old May 6, 2004 | 05:31 PM
B11GNS's Avatar
B11GNS
Default What grease?
What is the best stuff to use for the release bearing shaft and clutch arm pivot point on a 2wd cos?
Old May 6, 2004 | 07:19 PM
Dave Henshall's Avatar
Dave Henshall
castrol BNS high melt point grease
Old May 7, 2004 | 03:06 PM
B11GNS's Avatar
B11GNS
Cheers Dave.
Someone suggested copper slick, is that any good?
Old May 7, 2004 | 03:16 PM
Dave Henshall
copper"slip" - and no - its an anti seize compound for where parts don't actually move a lot, like brakes and bolts that need to come undone again(exhaust bolts etc) it does contain small particles of copper and its melt point is not very high at all and so would all drop off and foul the plate anyhow.
Old May 7, 2004 | 07:58 PM
B11GNS's Avatar
B11GNS
Cheers, think the person who told must have had a bit of a lisp hence it sounded like slick
Old May 9, 2004 | 09:29 AM
B11GNS's Avatar
B11GNS
Anyone else. Not disagreeing with you dave just wondering what other people use.
Old May 9, 2004 | 10:54 AM
Dave Henshall
now u got me thinking - ive always used that with no probs, but i found this,.... http://library.cbest.chevron.com/lub...9?OpenDocument which is moly based grease specifiaclly for that type of application
Old May 9, 2004 | 02:26 PM
HYBRiD_T's Avatar
HYBRiD_T
Yeah Molecote is the one!
Paul T
Old May 28, 2004 | 01:03 PM
B11GNS's Avatar
B11GNS
What company makes molecote grease?
Old May 28, 2004 | 05:12 PM
HYBRiD_T's Avatar
HYBRiD_T
Don't know but you can get it from Peugeot in a tube. Don't know the part number sorry.
Old Jun 17, 2004 | 01:11 PM
B11GNS's Avatar
B11GNS
i have got hold of some molykote grease, it has 'medium 33' on the side and the temp range is -73 to 180 degrees, is this ok?
Old Jun 18, 2004 | 11:02 AM
B11GNS's Avatar
B11GNS
Can anyone tell me if the above is any good for that application plz
Old Jun 18, 2004 | 12:28 PM
Uncle Henry's Avatar
Uncle Henry
I seriously hope your gearbox anint gonna see -73 or 180 degrees so it should be just fine!!
and copper slip cant have a low mwlting point or it wouldnt be much use on brakes would it That said you are not supposed to use it for clutches etc.
Just bang the stuff on you have got but dont put too much on - you dont want it all over the friction plate do you?
Old Jun 25, 2004 | 06:12 PM
nicksaph's Avatar
nicksaph
you shouldn't use copper slip because the particles of copper get inside the release and spigot bearings and cause them to fail! that is the explanation from lockheed or valeo i can't remember which. but if you think about it it makes sense.
Old Jun 26, 2004 | 04:25 PM
B11GNS's Avatar
B11GNS
i've got hold of some castrol high melt point moly based grease (dark grey in colour) so will use that, cheers for help peeps
155lee
Sep 23, 2015 01:27 PM
Adam Graham
Sep 6, 2015 06:04 AM
hopper350
Sep 4, 2015 12:53 AM
2wdsaph ben
Aug 17, 2015 03:17 PM
