Zetec s
Old Oct 18, 2013 | 07:38 PM
SCOTTY17's Avatar
SCOTTY17
Default Zetec s
Help am only getting 30.4 mpg out of my ford fiesta 1.6zetec s it does have k&n filter but shouldn't make that much difference it only standard filter. I've herd some one is getting 60 mpg from same car. HELP PLEASE !!!!!
Old Oct 18, 2013 | 09:23 PM
STeve's Avatar
Super Moderator
I would say high 30s is where they should be, but they can drink petrol and cone filters dont help thats for sure
Old Oct 18, 2013 | 09:38 PM
SBT83's Avatar
SBT83
Not Crazy, just Unwell
OP, Are you the owner of lead feet?
Cone filters if driven as you would an air box in theory should be more efficient. Cleaner colder volume of air creating a purer combustion along with a good regular service.
But with the sound and slight increase in power it's unlikely to be driven steadily by the average person.
Plus more Eco friendly than paper filters and last years so cheaper too. I've done plenty of research owning a filter company a few years back
Old Oct 22, 2013 | 01:00 PM
martysmartie's Avatar
martysmartie
Ford claim 40+ MPG in the heavier Focus! Given that these claims are never seen in the real world.
But it depends on your driving style and the conditions, i.e. if you are doing town driving this will equate to a considerable decrease in performance.
Martin
Old Oct 22, 2013 | 01:04 PM
martysmartie
That is not quite true, in some cases fitting a filter can make an engine run worse, if affected by heat soak, for example. Imo a decent panel filter is better than a cone and that the latter just create noise.
In the case and others the OE filter has a 'snorkel' fitted, so cool air is induced.
Martin
Old Oct 22, 2013 | 01:35 PM
SBT83's Avatar
SBT83
Originally Posted by martysmartie
That is not quite true, in some cases fitting a filter can make an engine run worse, if affected by heat soak, for example. Imo a decent panel filter is better than a cone and that the latter just create noise. In the case and others the OE filter has a 'snorkel' fitted, so cool air is induced. Martin
Very true. Fitting a heat shield can offer minimal protection. Cold air feeds are petty essential to a cramped engine bay where a filter is susceptible to heat. Other options are arguable like stainless filters will keep cooler than a foam or cotton but this offers less filtration than the other two.
And I have to agree on a decent panel filter in an air box can provide better gains than a heat soaked filter
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
SMILER258
Sep 28, 2015 09:04 AM
mondeomark
Sep 28, 2015 06:28 AM
focuspower
Sep 20, 2015 03:51 AM
