Cosworth tps setting
Old Aug 12, 2013 | 02:52 PM
rcr's Avatar
rcr
Default Cosworth tps setting
Hi,need info on tps setting. I have L6 ecu/pf09 tps and the two outer cables are switched. The voltage between pin11 and pin17 is 0,85v closed and 4,85v fully open. It goes bad between 1000-3000rpm after that it is near normal. Is this wrong? More that could be wrong with pf09 on L6 ecu?
Old Aug 12, 2013 | 04:42 PM
martysmartie's Avatar
martysmartie
You need a PF01 for that ECU, the design is different and contains a switch, your current one does not.
Martin
Old Aug 12, 2013 | 04:58 PM
anglia105e hinson's Avatar
anglia105e hinson
I had this same problem a month or so ago.
I didn't know I had a pf09 :-(
I had bad idle issues
Changed it to a pf01 like it should be on a l6
It's a pain to set up though. Because it has a switch inside.
You need to see as near to 0 volts as poss at closed throttle.
Then with the slightest movement on the throttle the switch opens and jumps to 5 volts
(Or as near too)
Then at wide open throttle back to 0 volts
I had
Closed - 0.35v
Slight movement - 4.5v
Wide open throttle - 0.2v
It had to decline in voltage as soon as you touch the throttle
Hope this helps
Luke
manuel boeckx
13
Oct 3, 2015 02:29 PM
FlashRS
Aug 30, 2015 08:07 PM
Steve Escos
Aug 24, 2015 07:56 AM
kosienutter
31
Aug 22, 2015 09:55 AM
Aug 14, 2015 07:29 AM
