air conditioning
Old Mar 19, 2005 | 03:25 PM
pilts's Avatar
pilts
Default air conditioning
HELP
I have a 2000 Focus TDDI LX. when I switch on the AIR CON, the little green light comes on but nothing happens. I have found the relevant relay in the fuse box and it does not appear to be energised. If I remove the relay and short out the relevant terminals, I can hear the compressor solenoid engage but still the air from the vents is not cold. Does anybody know if there is an interlock which prevents the compressor engaging if there is low gas pressure?
Any suggestions??
Old Mar 19, 2005 | 03:55 PM
alan rainbow's Avatar
alan rainbow
low pressure switch mate you will find it is short of gas the gas is r134a
Old Mar 19, 2005 | 04:29 PM
pilts's Avatar
pilts
Thanks for that! Just got to find someone to gas it up for me now. the local dealership don't have the facility.
Thanks again
Old Mar 19, 2005 | 06:31 PM
alan rainbow
where abouts are you
Old Mar 20, 2005 | 08:49 AM
pilts's Avatar
pilts
Cumbria (South Lakes, furness peninsula)
Old Mar 20, 2005 | 10:22 AM
ian sibbert's Avatar
ian sibbert
cumbria trnasmission in ulverston do it mate....or most air con companies...agrelek in barrow....someone like that or bring it lancaster and i'll get it done for you.....
Best regards
Ian
Old Mar 20, 2005 | 02:36 PM
pilts's Avatar
pilts
Cumbria transmissions is only about 4miles away. I'll give them a try.
Old Mar 20, 2005 | 06:49 PM
alan rainbow
I could of done it for ya mate but iam in notts
Old Mar 20, 2005 | 07:19 PM
foreigneRS's Avatar
foreigneRS
Testing the future
the question is, why is the system low on gas?
they do leak a certain amount over time, but it shouldn't be that much. no point just filling it again, find the leak first. also, how much oil have you lost? does that need topping up too? a professional company will see you right on these points, a bodger will just vacuum the system down and then fill it with gas. be careful with who you use, but one that's recomended should be good.
Old Mar 21, 2005 | 08:40 AM
pilts's Avatar
pilts
Cumbria Transmissions want £50.00 for the job. £25.00 to leak check and another £25.00 to re-gas. Doesn't sound to bad to me. what does anybody else think?
Old Mar 21, 2005 | 02:56 PM
ian sibbert
£50 is about right mate....most dealers want £60 - £80
Regards
Ian
Old Mar 21, 2005 | 06:44 PM
alan rainbow
this is a good price mate
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
Sep 28, 2015 10:05 AM
Russ Payne
Sep 25, 2015 08:29 PM
