RS turbo coolant level weirdness.
Old Jul 19, 2013 | 07:53 PM
Stu_K's Avatar
Stu_K
Unhappy RS turbo coolant level weirdness.
Now this may be coincidence but its worried me. I went to check the fluid levels on the rst tonite. The water is usually at the max line when stone cold but it was about 3 cm above. So I squeezed the hoses to see if they were full of water and in case of an air lock.
Then comes the worrying part. I took the oil cap off and the header tank started 'glugging' and the water level returned to normal. I had a new header tank cap to fit as last time I used it I noticed staining on the header tank where water had come out the cap.
Coincidence as I had just squeezed the pipes or does it indicate the headgaskets gone and the oil and water side are no longer seperate?
Old Jul 19, 2013 | 08:25 PM
SBT83's Avatar
SBT83
Not Crazy, just Unwell
Any mayo on the dip stick? Or oil traces in the water? It sounds sus!
Old Jul 19, 2013 | 08:28 PM
Stu_K's Avatar
Stu_K
No, no smoke either.
Old Jul 19, 2013 | 09:49 PM
SBT83's Avatar
SBT83
It's weird that there's water pressure in the lump! I have come across something slightly similar before on a nova gte I had. There was a small hole in the bore of one cylinder, right where the water duct was. When it ran it was perfect! Slight water from the exhaust but a normal sign of good combustion. Except if u screwed the cap of it would " gasp". Hence holding water pressure. Don't know if this helps at all but thought I'd mention it!
Old Jul 20, 2013 | 01:58 PM
Stu_K's Avatar
Stu_K
Weird. It didn't do it today done 100 miles on motorways and town traffic no over heating, drives fine. Must have been coincidence and my squeezing the pipes disturbed and air lock.
Thanks for the help though.
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
