Courier Van Timing Belt Change?
Old Jul 10, 2013 | 09:21 AM
axxeman's Avatar
axxeman
Default Courier Van Timing Belt Change?
Hello there, I have searched high and low but to no avail.
2001 1.8 TDi Ford Courier. What is the timing belt change interval please?
Thanks in advance.
Axxe
Old Jul 10, 2013 | 11:44 AM
Rowe's Avatar
Rowe
Skint
usually 10 years or 100,000 miles.
Old Jul 10, 2013 | 11:50 AM
axxeman's Avatar
axxeman
Thank you. I was thinking nearer 60k and 5 years. Would anyone realistically recommend leaving it that long? I only use the van for very light work and do around 28k per year but even so...
Thoughts please?
Axxe
Old Jul 10, 2013 | 11:53 AM
Rowe's Avatar
Rowe
Skint
Thoughts please?
Axxe
Personally. I'd change it.
Whenever i buy a secondhand car it gets a new belt on. That's just something i do.
Old Jul 10, 2013 | 12:12 PM
axxeman's Avatar
axxeman
Yeah, I just did. 185k and no service history so no brainer. I was very fortunate as many of the teeth had started to pull away from the belt. Was just a question of when, not if, it failed.
Made me consider changing it every 2 - 3 years irrespective of the mileage*
*(assuming it's still under 100k!)
Axxe
Old Jul 11, 2013 | 09:50 PM
perry3188's Avatar
perry3188
The older diesel engines are very common for snapping belts. For the escort van 1.8 na I think autodata gives 70k but every mechanic I've ever talked to about it says 20k without doubt.
Old Jul 11, 2013 | 10:29 PM
axxeman's Avatar
axxeman
Interesting reply, Mr Perry, Sir. My previous was indeed a 1.8 D n/a which had the belts changed some 2 years ago; maybe 2.5 years. Anyways, I snapped it after approx 42k, so I take your point. I learned the hard, and expensive, way!
Axxe
RUBY123
Oct 22, 2023 12:04 PM
cos elle
Sep 1, 2015 06:48 PM
taylora1409
Aug 12, 2015 12:06 PM
S3an
Aug 11, 2015 07:26 PM
vdubo7
Aug 2, 2015 08:17 PM
