Cosworth problems
Old Jul 9, 2013 | 01:02 PM
taycoss's Avatar
taycoss
Default Cosworth problems
Hi there a friend of mine bought a non running escos and brought it to me to have a look at. Checked it over and got running by cleaning crank sensor(now new) and its smokey. It started running like a bag of bolts the next day and traced this to in tank pump not supplying enough fuel to the swirl pot under the car. Changed tank pump and now starts and runs again but very rich and smoking.
The car has been a few places so unsure what has been tampered with or adjusted since the car used to run ok.
Checked compression and only around 110 psi on all cylinders but from what ive been told its a low compression engine. Is this too low? As standard would be around 150psi.
Unsure of mods to car but has 8 injectors, t4, air injectors,2 x fuel pumps with swirl pot ect.
Im not too clued up on these and more an evo person so any recommendations who to use for set up in Scotland? Or head down south?
Old Jul 9, 2013 | 01:16 PM
Ben26's Avatar
Ben26
would the low compression test point towards low comp pistons ??
im sure if the compression test was the same on all cylinder then that would be fine ??
sounds like it has good mods and could be belting out some good power when running right .
Old Jul 9, 2013 | 01:55 PM
taycoss's Avatar
taycoss
Thats what was thinking about the compression but not sure.
Leak down test showed ok too. Think its supposedly over the 500bhp mark.
manuel boeckx
13
Oct 3, 2015 02:29 PM
CLIVE
Oct 2, 2015 12:58 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Aug 14, 2015 07:29 AM
