Kent 244 camshaft
Old Jul 6, 2013 | 09:44 AM
Damianhs's Avatar
Damianhs
Lightbulb Kent 244 camshaft
i've just fitted a Kent 244 camshaft to my 1600 crossflow. I set the camshaft gear timing mark up to the crank gear timing mark, with the marks in line and close together. I,m now fitting the distributor so I've positioned cylinder no.1 at tdc on it's firing stroke. This leaves the timing marks in line but the camshaft gear mark is rotated 180 degrees. Shouldn't they be in line and close together. Hope this makes sense
Nov 1, 2015 06:53 PM
Marino
Sep 12, 2015 11:10 AM
