Stiff clutch when engines hot
Old Jun 26, 2013 | 12:48 PM
floydion's Avatar
floydion
Default Stiff clutch when engines hot
Hi all, ive used the search but cant find the answers im looking for.
Idrive a 97 escort van 1.8d non turbo
Ive been having this issue with my clutch for some time now, basically in the mornings when everythings cold my clutch works fine but after 10 miles the pedal gets really stiff and changing gear is impossible,
ive replaced the pedal box, clutch cable, ive had a new clutch fitted, 3 part clutch from local motor factors but i still have the same problem?
Ive had to replace the clutch arm twice due to them splitting on the shaft so im currently using a arm from a petrol as the weight on the diesel was fowling the casing, i replaced the release fork thinking it might be pushing the bearing uneven and ive lost count of how many quadrants ive broke!
Please could anyone help my scrapyards are running out of quadrants!
Old Jun 26, 2013 | 01:05 PM
Ben26's Avatar
Ben26
That sounds so random. Could it be something to do with the linkage its self ?? from under Stick to gearbox ?
Old Jun 26, 2013 | 01:38 PM
floydion's Avatar
floydion
I thought that so i replaced Lh rear and front engine mount to try and keep the linkage tight and steady and greased the linkage but that didnt help,
Old Jun 26, 2013 | 02:11 PM
fraser9764's Avatar
fraser9764
Is the clutch cable routed correctly? Its not sat against the exhaust manifold or got any big kinks in it?
Old Jun 26, 2013 | 02:31 PM
floydion's Avatar
floydion
as far as im aware its ok, its clipped to the bulkhead under the bar conecting the brake pedal to the master cylinder
Old Jun 26, 2013 | 04:04 PM
Ben26's Avatar
Ben26
Take the cable out and chuck Loads of oil down the sleeve maybe. Something is gettin hot and dry or hot and expanding causing a limiting movement either way??
Old Jun 26, 2013 | 10:24 PM
floydion's Avatar
floydion
funny you should say that ive been talking to the people from Big Licks Racing Coventry and thats what they think it is, thanks
SmudgerByName
52
Jul 28, 2016 06:14 PM
Adam-M
Aug 26, 2015 05:53 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
fish6634
Ford KA
Aug 2, 2015 01:02 PM
Old ford
Jul 31, 2015 06:50 AM
