help needed tdci problem
2003 focus tdci.
Wont start unless i use easy start.
When its started it runs bad.
Fault code is not enough fuel pressure.
New pressure switch and filter fitted and its the same.
The pump seems to be returning alot of fuel into the return pipe back to the tank like there is something switched off or the pump its self isnt working right.
How can i check the solonoid on the pump?
vdun01
Ford Fiesta
Oct 5, 2017 08:14 AM
