xr2/rst bottom end question
Old Jun 9, 2013 | 07:43 PM
judge dredge's Avatar
judge dredge
Default xr2/rst bottom end question
hi there I have just joined the site I have a quantum saloon kit car which I want to turbo at the moment it has a standard fiesta xr2 engine box ect but what im wondering is is there much diffrence from an xr2 bottom end to a rst fiesta or escort if not is it possible to use he top end loom every thing and keep the xr2 bottom its only done a genuine 34.000
any help welcomed thanks.
steven.
Old Jun 9, 2013 | 07:47 PM
RS 5tu's Avatar
RS 5tu
Turbo blocks have returns for the oil from the turbo and also different pistons to give a lower comp, will be much easier to just swap your bottom end for a turbo one and be far cheaper.
Old Jun 9, 2013 | 07:55 PM
frsjon's Avatar
frsjon
xr2 as it carb'd engine ? then no fit a frst complete engine (efi,no hole for crank sensor in xr2 block ) if it was a xr2i engine you had then it would be different
Old Jun 9, 2013 | 08:07 PM
judge dredge
dam yea its carbed thanks guys im kind of on a shoe string budget at the moment going to try buy things slowly and build it up from there with help of course thanks guys
Old Jun 9, 2013 | 08:13 PM
Ben26's Avatar
Ben26
check this out mate .. could help you out
http://www.ebay.co.uk/itm/Ford-Fiest...item3a81e8a6b6
Music & Car Audio Chat
Sep 3, 2017 01:24 PM
BRAMMER
15
Sep 14, 2015 08:52 PM
Tank Mike
Sep 10, 2015 07:56 AM
andrewmctiernan
Sep 8, 2015 03:05 PM
