Weird Misfire
Old May 2, 2004 | 03:12 PM
Nik_W's Avatar
Nik_W
Default Weird Misfire
Right first up is my spec, t34 turbo, 4x4 I/C, 803s, 3 bar map sensor, ahmed bayjoo stage 3 chip, group A headgasket. I had this problem when I was at stage 1 but it wasn't that noticable. When you boot her it missed a touch but kept pulling fine, but now I have gone to stage 3 and running around 20psi the problem is worse. I bought the plugs from harvey gibbs for stage 3 and even tried a mates plugs but the problem is still there. I have a new crank sensor and the gap is around 0.6mm, plugs are just under 0.7mm. I also put a new rotor arm in. Basically, when I boot it in 2nd and 3rd it is very bad but if I put my foot down just a touch where I get a reading of around 18psi it's not too bad. I hardly noticed this problem in 4th & 5th which I found odd. Also, on tickover it sounds quite lumpy with a bubbling/popping sound from the exhaust.
Any ideas?
Old May 2, 2004 | 04:45 PM
swerv's Avatar
swerv
what plugs you running? 071's??
have you had a pectel on it to check all sensor's??
Old May 2, 2004 | 05:02 PM
Nik_W's Avatar
Nik_W
Just solved problem and feel a bit silly about it
Changed dizzy cap and it's running sweet now
Thanks matey! and yea I am running 071s.
Old May 2, 2004 | 05:47 PM
swerv's Avatar
swerv
yeh any more probs and launch the plugs into the back garden
j.hammond1
30
Oct 31, 2021 05:28 PM
Brickhouse
Sep 21, 2015 11:00 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
taylora1409
Aug 12, 2015 12:06 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
