st170 help
Old May 14, 2013 | 09:08 PM
tonyp5467's Avatar
tonyp5467
if in doubt .....flat out
Default st170 help
hi does anyone know if the st170 front stub axle/hubs are same as the ones on lower spec cars ie will one off a lx or ghia fit or are they different ?
I know it would need to be the abs type but will the caliper carrier fit from my st onto a non st hub ?
all help appreciated
Old May 14, 2013 | 09:17 PM
RichieST's Avatar
RichieST
the knuckles are st170 specific as the brake setup is quite different, not sure about the hubs think they are the same.
Old May 14, 2013 | 11:53 PM
tonyp5467's Avatar
tonyp5467
ok thanks for that
I think my best bet is to replace the bearing and also the hub if that is required
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Sp3no
Sep 27, 2015 07:23 PM
Marv888
Sep 26, 2015 03:44 PM
Andypandy260
Sep 23, 2015 10:28 PM
pie-face
Sep 15, 2015 10:43 AM
