Radio wire diagram?
Old Mar 16, 2005 | 12:16 PM
cav-mad-gav's Avatar
cav-mad-gav
Default Radio wire diagram?
hi all, im going to be installing a aftermarket headunit for a mate in a J reg Fiesta.
Will it plug straight in or do some wires need chaging over.
i take it its the standard connector type, the double DIN isit??
cheers all
Old Mar 16, 2005 | 09:16 PM
Moonie's Avatar
Moonie
If the fiesta has the origional din connections then you will just have to plug the head unit in (sometimes you need to reverse the live/ignition live). If its had the din connections cut off then its time to get your self a testlight and some connectors.
Old Mar 16, 2005 | 09:20 PM
daz1968's Avatar
daz1968
If std ford connectors then halfords do conversion plugs to std din, so just plug into loom then into head unit and slot in, no wiring to do at all, I used one on mine to fit a sony headunit in, really easy think adaptor was about £15
Old Mar 17, 2005 | 08:21 AM
cav-mad-gav
The conversion plug your on about Daz.....when i brought one for my cavalier i later found out all i needed todo was swap the red wire and the yellow wire, so i was miffed at spedning £10 on it! lol
Moonie.......what colour wires would need swaping around then?
And how do you tell if they need swaping? Isit if the radio works all the time and doesnt remeber any settings?
Old Mar 17, 2005 | 07:16 PM
Moonie's Avatar
Moonie
Its the permanent power feed and ignition feed (red and yellow wires) that are sometimes the wrong way round. As you say if they are the wrong way you will loose you radio preset stations when you turn the ignition off.
Old Mar 18, 2005 | 07:13 AM
cav-mad-gav
cool
thanks guy's
i'll score some brownie points with the lady owner of the car hehe
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
IainRS1700T
Sep 25, 2015 06:44 AM
THE RADMAN
Sep 19, 2015 12:57 PM
