Clutch slipping
Old May 3, 2013 | 10:29 AM
timsrs's Avatar
timsrs
Default Clutch slipping
My clutch has started slipping ,i noticed the other day when traveling on a dual carrageway in top gear accelerating on boost.
i have stripped the clutch out and the plate looks in good condition.
I did notice that the pressure plate was an after market item and i have no idea of make, again this was in good condition.
The flywheel looked good geenerally, but you could see where it had been slipping and getting hot.
What do people use as a clutch set up, i have heard that the standard pressure plate is best, please enlighten me with info on what i should buy.
The car is running stage 3 circa 350bhp.
Mnay, many thanks
Tim
Old May 3, 2013 | 12:29 PM
martysmartie's Avatar
martysmartie
I just have an uprated plate, it also has been known for a Transit clutch to be used, lol!
Perhaps your flywheel needs 'skimming'?
Martin
Old May 3, 2013 | 01:01 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
I went for a 6 paddle AP plate clutch, seems to work well even when I use the nitrous on top of the stage 3.
Old May 3, 2013 | 03:12 PM
timsrs's Avatar
timsrs
Default clutch slipping
Thought the flywheels were hardened steel and skimming removes the hardened surface..may be wrong/???????
Martin
Old May 3, 2013 | 06:51 PM
costina's Avatar
costina
Live long and prosper!!
Prob a shitty techniclutch
Old May 4, 2013 | 08:25 AM
timsrs's Avatar
timsrs
Default clutch
Thanks i have no idea what clutch it is....
What kit would you use that will be good
Thanks
Tim
Old May 4, 2013 | 10:15 AM
martysmartie
I don't know tbh, I was just going ny a conventional case where the flywheel has been 'glazed'.
Martin
Old May 4, 2013 | 11:15 AM
anglia105e hinson's Avatar
anglia105e hinson
My 4x4 flywheel is on its 3rd skim still fine .
I've gone through a few clutches now .
The one that's in it now is a brand new standard ford Delphi cover plate with ap 6-paddle .
And is fine .
My last one lasted bout a year, I launch it all the time and go drag racing 4 times a year. Was perfect until the paddle wore out.
Just got it re-lined and put it back. No problems .
Old May 4, 2013 | 07:21 PM
costina's Avatar
costina
Martin
cossie flywheels are steel not cast and its better to have them ground
I'd go for a helix organic
Old May 4, 2013 | 08:48 PM
timsrs's Avatar
timsrs
Default clutch slip
I would like to put a standard ford pressure plate back as the pedal will feel light and normal, but are they still available now,
Tim
Old May 4, 2013 | 09:21 PM
botters's Avatar
botters
competant bodger
standard clutches are ok at that power so long as you dont do too many hard launches, smiley face transit turbo ones work as well and are cheeep lol
Old May 5, 2013 | 12:37 PM
timsrs's Avatar
timsrs
Default clutch
So would something like an AP complete kit be good and last.
But would this make the pedal hard ?????
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
