taking out a 4x4 sapph cossie engine
Old May 1, 2004 | 04:21 PM
Default taking out a 4x4 sapph cossie engine
i need to take my 4x4 saphh cossie engine out to rebuild the bottom end. how hard is it to remove? i take it i have to drop it out the bottom? any tips to help me would be good
Old May 1, 2004 | 04:56 PM
In a previous thread, someone said they managed to lift the car high enough to slide the engine out the front, the correct procedure (as per workshop manual) is to lift the engine out though.
Old May 1, 2004 | 04:59 PM
DazC's Avatar
DazC
When we did my Dad's, we dropped the engine and box down still mounted on the crosmember with all the streering and suspension still attatched. Was pretty easy this way but still just as long winded.
Old May 1, 2004 | 05:15 PM
dave cos4x4's Avatar
dave cos4x4
Posted: Sat May 01, 2004 5:56 pm Post subject:
Might have been me saying that.
This way,to me is the easiest,having done it pleanty of times.
Hook engine crane to take the weight of the engine, undo all the prop,box mounts,subframe bolts etc.....then i put a small flat trolley under the subframe and then lowered the engine down so it sits on the trolley, undo the engine crane and i hooked it onto the towing eye,then lifted the car high enough so i could wheel the engine,box etc..... all in one out around the crane legs.
Do what you have to do,wheel engine back under,lower car on stands and hook up engine,lift it back in place and bolt subframe back on.
Do get a trolley though(i used a flat crate one that bread gets wheeled around on) or you cannot get the engine ,box etc...back under the car.
i done this on my own in a few hours.
Dave.
Old May 1, 2004 | 05:26 PM
is it possible to lift the engine out the top?? i know you can on 2wd cossies but not sure on the 4x4's
Old May 1, 2004 | 09:01 PM
The Youth.'s Avatar
The Youth.
you can't lift a 4x4 out unless you undo the sump bolts and leave it there or remove the front driveshafts.
steve
Old May 1, 2004 | 10:00 PM
thought so, looks like it out the bottom then. not looking forward to it
cheers
big_Rad
Sep 15, 2017 09:36 AM
Karl 3dr
102
Oct 14, 2016 08:17 PM
pegaz
11
Aug 9, 2015 06:40 PM
MARKYMARKONE
Aug 2, 2015 09:33 PM
Old ford
Jul 31, 2015 06:50 AM
