Cosworth running issues
Old Apr 29, 2013 | 06:44 PM
cozi500's Avatar
cozi500
Default Cosworth running issues
Hi all i recently took my cosworth out for a drive, after around 30 minutes of driving at around 5000 rpm the engine seemed to die and the throttle wouldnt respond. I pulled over and the engine was ticking over as normal, but when i tried to give it some throttle it wouldn't respond, after about a minute all was fine again. The same happened again today. Any ideas, TPS? coil breaking down? any help please,
Old Apr 29, 2013 | 06:47 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
Look at map sensor
Old Apr 29, 2013 | 06:59 PM
cozi500's Avatar
cozi500
Originally Posted by Richie.
Look at map sensor
Would the Map sensor do this? Everything was ok until i put a autospecialist intake manifold on, no leaks, but i have had to Tee into the map sensor hose, for the dump valve, would this affect the map?
Old Apr 29, 2013 | 07:02 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
Check map sensor connections inside the plug, I had similar symptoms which turned out to be a broken wire/pin.
Chas
Sep 21, 2015 08:57 PM
ekjim
Aug 17, 2015 08:57 PM
Aug 14, 2015 07:29 AM
yawiejon
15
Aug 9, 2015 06:36 PM
Red_bull
Aug 9, 2015 08:34 AM
