s1 problems
Old Mar 14, 2005 | 02:25 PM
RSTEVE's Avatar
RSTEVE
Default s1 problems
got a mk3 cab with a 1600 cvh turbo engine, stg2 turbo, cam, chipped etc... runing 198bhp. recently went to run it lots of white smoke and flames unable to get any power when acelrateor pressed like its missing baddly , it starts ok but once it warms up cuts out, though it could of been a head gasket, had a spare head so c the head was changed and pistons where checked and ok, started after this but once warm the same problem, might be over fuelling but the fuel metering head has been changed and no diffrence any one got any ideas ??? get pretty desprate car been of the road for a while. not that great at the mechanics side but slowly learning on this car so can any replys be in simple talk sorry
thanks
steve
Old Mar 14, 2005 | 03:24 PM
cpcossie's Avatar
cpcossie
check the cylinder compressions, could have a piston gone and you wouldnt see it unless you take the pistons out
Old Mar 14, 2005 | 03:40 PM
RSTEVE's Avatar
RSTEVE
the local garage i took it to said the timimg was out and i may have bent a valve cause the there was no compresion in cyl number 1,
but will get some help, thanks for the advice
anyone know of a good rs garage or mechanic in north wales ????
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
