Transit Chipped Key / Lock Set
Old Feb 26, 2013 | 08:26 PM
Olli2004's Avatar
Olli2004
Question Transit Chipped Key / Lock Set
Hi all,
Last weekend I purchased an R reg Transit. Unfortunately the key is badly worn and I'm worried it might just stop working if it gets any worse.
I'm not sure whether to just buy a blank key and try and have it copied or to get a new lock set. If I just try and get it copied is the chip easy enough to swap over to the new key? Does the red tab just flick out and the chip comes out?
If I fit a new lock set is there a way of coding a new chipped key without going to the stealers?
Thanks
Olli
Old Feb 26, 2013 | 09:42 PM
james kiely's Avatar
james kiely
i think if you bring it to your ford dealer with your logbook they will set you up with a new one from the chasis number
Old Feb 27, 2013 | 08:55 PM
martysmartie's Avatar
martysmartie
You should be able to just put the 'transponder' in a different key.
Martin
FlashRS
Aug 30, 2015 08:07 PM
SteveyDee
Aug 25, 2015 07:48 PM
Steve Escos
Aug 24, 2015 07:56 AM
rst-s1
Aug 23, 2015 07:56 AM
tankybaby66
Aug 9, 2015 07:13 AM
