need help wiring a rave limiter!!
Old Feb 14, 2013 | 01:06 PM
Declan Gallen's Avatar
Declan Gallen
Default need help wiring a rave limiter!!
i have 3 1.8 cvh sierra. im trying to wire the rave limiter. there is a yellow and green wire, a red and green wire and a black wire coming from the coil pack. there is a black white and red on the rave limiter. the instructions are "Connect as follows black wire to earth red wire to coil +Terminal white wire to coil _ terminal. any idea what is the terminal + and Terminal_ is coming from the coil pack??
Old Feb 14, 2013 | 01:11 PM
DaveCrack's Avatar
DaveCrack
why you wanna limit your rave!!?!? Party on Garth!!!
Old Feb 14, 2013 | 01:12 PM
Beach's Avatar
Beach
There is no limit to raving!!!!
Old Feb 14, 2013 | 01:16 PM
Declan Gallen
i want it, cause it sound good. any idea how u do it?
rsnissan's Avatar
rsnissan
Life Begins at 140BPM's
Old Feb 14, 2013 | 01:18 PM
doga-ot's Avatar
doga-ot
Bud look at you coil it has 2 push on plugs 1 smaller than the other it will have a +&- next to each plug i think the bigger 1 is + smaller is -
Old Feb 14, 2013 | 01:19 PM
RichieST's Avatar
RichieST
Rave on!
Old Feb 14, 2013 | 02:36 PM
Declan Gallen
how do i put up the pic so u can see what im talking about?
Old Feb 14, 2013 | 02:49 PM
rog's Avatar
rog
Like this?
Old Feb 14, 2013 | 02:51 PM
doga-ot's Avatar
doga-ot
Upload your pics to photobucket its free then copy the url(web address) and paste on here
Old Feb 14, 2013 | 02:56 PM
Declan Gallen
Old Feb 14, 2013 | 02:57 PM
Declan Gallen
Declan Gallen
Declan Gallen
Old Feb 14, 2013 | 02:58 PM
Declan Gallen
Old Feb 14, 2013 | 03:01 PM
Declan Gallen
what do u think
Old Feb 14, 2013 | 03:19 PM
dojj's Avatar
dojj
Resident Wrestling Legend
honestly?
you need to get the focus correct on the camera before you post any more blury pics up
i'm sure we can help you but first we need to see what engine it's got fitted to it and on that age of sierra it may have a cat fitted so it will have different wiring (the cat cars came with coil packs in some cases) so it's all a bit up in the air until we see a pic of your coil if it's the standard one or the coil packs (if it's got them fitted)
don't mean to sound harsh, just it is
Old Feb 14, 2013 | 03:22 PM
RichieST's Avatar
RichieST
And we still need to know your preferred BPM as you might not need to limit your rave.
Old Feb 14, 2013 | 03:54 PM
dojj's Avatar
dojj
or you may already have a self built rave limiter set
Old Feb 14, 2013 | 05:17 PM
MONSTER's Avatar
MONSTER
afpmsl
Old Feb 15, 2013 | 06:37 PM
costina's Avatar
costina
Live long and prosper!!
Why would you even bother on a 1.8 cvh they dont even rev well with those naff roller cam followers
sure they have a limiter as std prob around 6250 rpm your rev counter will have a dot on it were it is.
Find a very long road and in 2nd try to reach it if it judders then it has one. if not you have just wasted half hour trying to get there.
Old Feb 15, 2013 | 11:07 PM
Declan Gallen
its a 1993 ford sierra 1.8cvh coil packs whit a cat
Old Feb 15, 2013 | 11:12 PM
dojj's Avatar
dojj
Then you may not be able to wire one in if its not designed to run with coil packs
Do you want to cut the spark or cut the fuel?
Old Feb 15, 2013 | 11:21 PM
Declan Gallen
spark
Old Feb 16, 2013 | 06:56 AM
dojj's Avatar
dojj
http://forum.fordsierraclub.co.uk/viewforum.php?f=6
if that link wants you to register then do so
Old Feb 16, 2013 | 10:37 AM
Declan Gallen
i did no good
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
SMILER258
Sep 28, 2015 09:04 AM
