Help before i set it on fire :(
Old Jan 21, 2013 | 09:19 PM
spud-rs2k123's Avatar
spud-rs2k123
Default Help before i set it on fire :(
I brought me a rs turbo the other week on the road with tax mot and running
Anyway I parked it up on my drive with a cover over it done few little jobs to it like vacuum it clean it etc and just make sure everything was tidy under the bonnet. Car still running.
Then went to it a few days ago and it's a no go would start for love na money
So I've
Checked timing
Checked spark
Checked wiring
Checked for air leaks
Changed dizzy
Changed leads
Changed injectors
Changed ecu
Changed plugs and leads
Still no go
Car turns over fine but just won't fire seems to just fill the bores of fuel also has a funny squeak when the pump primes from under the bonnet
If I remove the fuel pump relay after a few cranks it will fire but wont start guess thi is no fuel has relay unplugged
So any ideas it really isndriving me mad now and I have no other idea what it could be
Any help would be great thank you
Old Jan 22, 2013 | 06:04 PM
minder's Avatar
minder
So I've
Checked timing
Checked spark
Checked wiring
Changed dizzy
Changed leads
Changed injectors
Changed ecu
Still no go
have you checked the roto arm these can brake down and stop the car from starting
Old Jan 22, 2013 | 06:07 PM
the_frozen_one's Avatar
the_frozen_one
The coil is missing from the list, you changed it and forgot to write it up or haven't you changed it? Did you work through methodically or just swap parts AA style?
Old Jan 22, 2013 | 06:25 PM
Piston Broke's Avatar
Piston Broke
The funny speak is the key fella its over fueling, if the cold start is unpluged you are looking at a fault with the TPS fella, it doesnt know where you value is for fuel of the throttle, norm if you move it by hand under the bonnet you should hear a click etc, there are known for going and people (90%) SAY ITS METERING WHEN ITS NOT !, im a ford mechanic of many years and spesh in work rally cars, norm historic etc working for some nice names
Old Jan 22, 2013 | 06:28 PM
Piston Broke
What ever you do by the way dont touch the CO value ! most people fiddle with the screw while trying to sort it, if you get in big tits up probs and give up im in north yorks and could always sort it !
DixieTheKid
11
Jun 6, 2020 11:20 AM
Jun 26, 2017 06:18 PM
DixieTheKid
Sep 14, 2015 09:04 PM
3doorcozmess
Sep 7, 2015 01:32 PM
hopper350
Sep 4, 2015 12:53 AM
