fuel gauge
Old Mar 10, 2005 | 08:01 PM
rs cab's Avatar
rs cab
Default fuel gauge
Hi everyone,i have MK3 1.6I cabby that cuts out when low on fuel ( between quarter and the yellow) when braking hard, i can hear the pump running dry once stopped it starts fine. Its got a new sender unit, a new tank and i changed the gauge aswell. anyone got any ideas why
Thanks
Richie
Old Mar 17, 2005 | 10:24 PM
Ally Young S1's Avatar
Ally Young S1
Have you got the right tank ? - The injection tanks has a baffle/swirl pot that holds fuel at the pick up point (i.e @ pump up line) so when you go round corners all the fuel runs to one side of the tank but the baffle is still full. The carb version of the tank doesnt have the baffle.
You may have fitted the gauge sensor wrong - its easy to do. You could have fitted 90 degrees out ? That may account for the gauge reading wrong.
Hope this helps.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
20/20 vision
Sep 29, 2015 11:27 AM
